Hey, I think about to buy the Sony PJ410 as a new cam for my greenscreen project. Has anybody experience with this cam via USB live?
Thanks bluelagune
Joined: 3/7/2012(UTC) Posts: 2,688  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ bluelagune
What is "USB Live"? As near as I can figure, the USB 2 port is only for file transfers and charging... A nice camera for sure, but I'm not familiar with what you might have heard about it, can you elaborate?
Joined: 2/9/2013(UTC) Posts: 265 Location: Katy, Texas
I have several similar Sony models (cx260, pj260). The only way to capture live output is via the composite or hdmi output.
At the Sony describtion stands there is a Live View Option. At a local store a shop assistant told me that there exists a possibility to stream via usb. But i havent heard about such an option bevore, thats why I am asking. Cause it sound a little bit to good... ( My budget has no space for a hdmi input card, thats why this option interessts me) Coud anybody test this maybe with his cam?
Thank you very very much for help:D
The Sony PJ410 can stream to Ustream, but that seems to be with WiFi, and playing back a recorded video from the camera.
You should be able to find the complete user's manual online, then read about the live view option.
Are you using a laptop or a desktop with vMix?
Joined: 8/5/2013(UTC) Posts: 280  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
Bluelagune, get a cheaper but similar camera like sony hdr 405 and usb grabber extremecap u3 http://www.ebay.de/itm/A...MI-USB-3-0-/281851485778If you use normal pc (not laptop) then buy blackmagic mini recorder. Dont count that options like live view or something like this on 350 eur camera will work well.
