We are getting and audio stutter within VMIX, but not as exported clips or the source replay recordings. Version 16.0.0.106x64
The source camera audio is also fine.
We have tried multiple bit rate settings.
We are using the AJA IO 4K.
Joined: 1/13/2010(UTC) Posts: 5,324  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Does the stutter occur all the time or only some of the time during playback? Is the audio source for replay set to master or one of the cameras audio? What are the specs of the system?
Thanks,
Martin vMix
Issue is constant (first 5 seconds seem to OK, 20 if we drop the nitrate) Audio is master i7 4770 with 780 gtx and SSD
The actual working file for replay and exported clips are fine
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ eslproduction
I am a little confused... 'Exported' replay clips are fine but during 'Instant Replay' "Live" playback the audio stutters, is that correct? Is this observable in the 'Broadcast' master recording? If so, can you provide or share a clip that illustrates the issue?
I'm getting the same thing in version 16. This issues is driving me nuts. vMix customer service: Are you aware of this issue. I depend on the Instant Replay feature to live stream our message out the same time every Sunday. Please give us some feedback on this issue.
In the meantime I went back to version 15 and now the audio that shows to be playing doesn't send to my stream at all (YouTube).
- Paul ed21.com
I fix my problem with a simple firmware update to Black Desktop Video 10.5.2. Really odd that this is what was creating the stutter.
Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
have the same problem, audio stutter in the vmix instant replay. aja kona lhi and the files have stutter to.
