aircooled76@gmail.com
#1 Posted : Thursday, November 26, 2015 6:07:47 PM(UTC)
Hi Guys,
Recently back from Mexico doing some Ultimate Frisbee production...
The first day and a bit the live stream did not work and I recorded in MagicYUV codec .avi's.
The video files play fine with audio in VLC. When I went to import them into Premiere CC to render out for publishing, Premiere conformed the audio but I only got the first minute or so of it in the timeline with the rest blank.
When I extracted the audio and re-synced and exported the timeline would export most of the sequence but get stuck on a random frame and freeze there for the remainder of the export.
I am currently testing the same files on a different machine with Adobe Premiere CS6 and the audio appears to be working OK.
However the following problem with it not importing the whole clip is happening on both machines:
There is also an instance where Premiere only imports the first 0:53 of a sequence that plays in VLC as a 33 minute clip.
Screen Shot: https://drive.google.com/file/d/...a01mM1E/view?usp=sharing
Log file from Recording:
Code:
18/11/2015 2:44:01 PM, Version: 16.0.0.106 x64
18/11/2015 2:44:01 PM, Size: 1280x720
18/11/2015 2:44:01 PM, System: PAL 50p
18/11/2015 2:44:01 PM, Codec: MagicYUV lossless video codec v1.1 (64 bit)
18/11/2015 2:44:01 PM, Format: UYVY 16 1498831189
18/11/2015 2:44:01 PM, AudioDevice: vMix Audio
18/11/2015 2:44:01 PM, AudioFormat: 48000 Hz 16 Bit 2 Channels
18/11/2015 2:44:01 PM, AudioDelay: 0
18/11/2015 2:44:01 PM, RestartInterval: 0
18/11/2015 2:44:01 PM, Buffers: 10
18/11/2015 2:44:01 PM, BitRate: 8
18/11/2015 2:47:10 PM, StartRecording
18/11/2015 3:23:51 PM, StopRecording
18/11/2015 3:23:51 PM, Duration: 00:36:41
18/11/2015 3:23:51 PM, Frames: 110049
18/11/2015 3:23:51 PM, DroppedFrames: 0
18/11/2015 3:23:51 PM,   DueToSourceFrameRate: 0
18/11/2015 3:23:51 PM,   DueToHardDiskOrCPU: 0
18/11/2015 3:23:51 PM, DroppedSamples: 0
18/11/2015 3:23:51 PM, MissedSamples: 0
18/11/2015 3:23:51 PM, SyncedSamples: 0
18/11/2015 3:23:51 PM, AudioOffset: -20
18/11/2015 3:23:51 PM, AudioDelay: 0
18/11/2015 3:23:51 PM, AudioEngine
18/11/2015 3:23:51 PM,   Running: True
18/11/2015 3:23:51 PM,   SampleRate: 48000hz 16 Bit
18/11/2015 3:23:51 PM,   MixingErrors: 0
18/11/2015 3:23:51 PM,     Streams
18/11/2015 3:23:51 PM,       Mixer
18/11/2015 3:23:51 PM,         Samples: 517597
18/11/2015 3:23:51 PM,         Dropped: Read 0 Write 0
18/11/2015 3:23:51 PM,         Latency: 0 ms
18/11/2015 3:23:51 PM,         Errors: 0
18/11/2015 3:23:51 PM,       Headphones
18/11/2015 3:23:51 PM,         Samples: 517582
18/11/2015 3:23:51 PM,         Dropped: Read 15 Write 0
18/11/2015 3:23:51 PM,         Latency: 20 ms
18/11/2015 3:23:51 PM,       DirectShow
18/11/2015 3:23:51 PM,         Samples: 517502
18/11/2015 3:23:51 PM,         Dropped: Read 18 Write 0
18/11/2015 3:23:51 PM,         TargetLatency: 40 ms
18/11/2015 3:23:51 PM,         Resampled: 280/40
18/11/2015 3:23:51 PM,       Replay
18/11/2015 3:23:51 PM,         Samples: 49217
18/11/2015 3:23:51 PM,         Dropped: Read 34 Write 0
18/11/2015 3:23:51 PM,         Latency: 220 ms
18/11/2015 3:23:51 PM,         TargetLatency: 200 ms
18/11/2015 3:23:51 PM,         Resampled: 440/680
18/11/2015 3:23:51 PM,         Samples: 76547
18/11/2015 3:23:51 PM,         Dropped: Read 47 Write 0
18/11/2015 3:23:51 PM,         Latency: 1020 ms
18/11/2015 3:23:51 PM,         Samples: 2807
18/11/2015 3:23:51 PM,         Dropped: Read 1 Write 0
18/11/2015 3:23:51 PM,       FFMpeg
18/11/2015 3:23:51 PM,         Samples: 100
18/11/2015 3:23:51 PM,         Latency: 1000 ms
Just wondering if anyone has any ideas what is causing this issue (it has massively slowed down my workflow in this case.) Some googling pointed me to the file possibly having incorrect header information... any ideas?
thanks
Mike
Stealth77
#2 Posted : Friday, November 27, 2015 1:05:35 AM(UTC)
Stealth77
Russian Federation
Was thanked: 8 time(s) in 4 post(s)
Hi.
The premiere of you conforming reaches the end or you're trying to play a sound immediately after importing the video?
If you can lay out what this video that I tried it at home.
#3 Posted : Friday, November 27, 2015 3:23:27 AM(UTC)
If it is some kind of AVI indexing issue, may need to download VirtualDub
open it up in there then from the Video and Audio menus select "direct stream copy" and save it out again as a brand new avi file.
#4 Posted : Friday, November 27, 2015 5:41:32 AM(UTC)
Thanks for the replies... Virtual dub stream copy fixed the problem. Ideally I wouldn't have to do this as it slows things down, but is a faster fix (and a great video tool) Thanks for the tip.
The audio thing is a bit puzzling... seems specific to my other computer... Ill do some more testing on that (it is not the conforming thing... I waited for it to complete... but it did not make any difference)
#5 Posted : Friday, November 27, 2015 10:48:29 AM(UTC)
@ aircooled76@gmail.com
What other AVI codecs are available to you?
I have had good results working with "GoPro-Cineform Codec [x64]" in 'Premiere Pro'.
Mathijs
#6 Posted : Wednesday, January 13, 2016 1:26:52 PM(UTC)
Mathijs
Sorry for bumping an older thread, but I had this indexing issue happening for the second time now.
Playing in mediaplayer, normal length. Imported into Premiere, 1min33sec.
The first time I encountered this, I was happy to find this thread.
But this shouldn't happen of course, it also takes up time to do the direct stream copy, while I most of the time like to render a rough version for the client during breakdown.
I am wondering how this happens though, at both times, I started and stopped the recording without anything weird going on in between.
I would expect this kind of thing from crashes while recording, but not when everything is going fine.
