Feature Requests
AverMedia Live Gamer Portable
Joined: 11/18/2015(UTC) Posts: 1 Location: California
I saw the founder Martin Sinclair at Streaming Media West conference in Huntington Beach,Didn't know this did not work. I would also like the Avermedia Live Gamer Portable to work with Vmix, all the low cost Elgato and Avermedia products should work, They work fine in OBS. Please consider adding the code to be compatible with the Avermedia product. Thanks
A better solution for you is the EasyCap U3 which is compatible with vMix 64bit. The LGP is great as a recorder/streamer when used with vMix rather than as a capture device because the Stream Engine software introduces significant latency.
Feature Requests
