videologic
#1 Posted : Wednesday, September 30, 2015 4:11:43 PM(UTC)
videologic
The AverMedia Live Gamer Portable is an very affordable converter. See:
http://www.amazon.com/AV...360-60Mbps/dp/B00B2IZ3B0
But it doesn't work with the 64 bit version of Vmix. See also the post :
http://forums.vmix.com/d....aspx?g=posts&t=1359
Can you make it work with a new version?
Thanks,
Rgds, Daan
Tede
#2 Posted : Wednesday, November 18, 2015 8:29:49 PM(UTC)
Tede
I saw the founder Martin Sinclair at Streaming Media West conference in Huntington Beach,Didn't know this did not work.
I would also like the Avermedia Live Gamer Portable to work with Vmix, all the low cost Elgato and Avermedia products should work,
They work fine in OBS.
Please consider adding the code to be compatible with the Avermedia product.
ask
#3 Posted : Wednesday, November 18, 2015 9:05:51 PM(UTC)
ask
A better solution for you is the EasyCap U3 which is compatible with vMix 64bit. The LGP is great as a recorder/streamer when used with vMix rather than as a capture device because the Stream Engine software introduces significant latency.
Similar Topics
Question for Avermedia Live Gamer Portable (LGP), model C875 (Hardware Compatibility)
by picarddontoro 3/25/2014 5:26:31 PM(UTC)
Anyone tried vmix with the new AverMedia Live Gamer Portable? (Hardware Compatibility)
by mmorlan62 9/24/2013 3:36:47 PM(UTC)
