melody
#1 Posted : Friday, June 29, 2012 10:41:07 AM(UTC)
Rank: Guest
Groups:
hi martin,
is there any possibility to implement a non-square pixel for the resolutions of the external output?
the idea is for user to have the ability to choose 3:4, 4:3, 5:4, 16:9, 16:10... it is important to avoid resize artifacts.
thank you for the attention
regards,
melody
www.espiritosanto.cc
#2 Posted : Friday, June 29, 2012 10:59:19 PM(UTC)
What program are you using the external output in? The aspect ratio will need to be set there.
melody
#3 Posted : Saturday, June 30, 2012 5:35:33 AM(UTC)
Rank: Guest
Groups:
im using FMLE, Windows Live Messenger for video call and veetle broadcast.
as you know, some programs or live broadcast web sites have limitations about aspect ratio, resolution, quality, etc... and about AR, it may cause undesirable black borders.
this request is based on a way to avoid black borders from the source without changing to HD resolutions if we want to use 16:9 aspect ratio.
thank you for reply, regards,
melody
ps: i liked off air message on external output, nice.
#4 Posted : Saturday, June 30, 2012 5:39:36 AM(UTC)
v3 will include some more widescreen output resolutions such as 720x405 and 640x360
melody
#5 Posted : Saturday, June 30, 2012 5:49:03 AM(UTC)
Rank: Guest
Groups:
thank you very much martin, this aditional resolutions will be apreciated.
if is possible, try to add 864x480 and 1024x756
best regards,
melody
