non-square pixel aspect ratio for resolutions of the external output
Rank: Guest
Groups: Guests
hi martin, is there any possibility to implement a non-square pixel for the resolutions of the external output? the idea is for user to have the ability to choose 3:4, 4:3, 5:4, 16:9, 16:10... it is important to avoid resize artifacts. thank you for the attention regards, melody www.espiritosanto.cc
Joined: 1/13/2010(UTC) Posts: 5,364  Location: Gold Coast, Australia Was thanked: 4784 time(s) in 1641 post(s)
What program are you using the external output in? The aspect ratio will need to be set there.
Martin vMix
Rank: Guest
Groups: Guests
im using FMLE, Windows Live Messenger for video call and veetle broadcast. as you know, some programs or live broadcast web sites have limitations about aspect ratio, resolution, quality, etc... and about AR, it may cause undesirable black borders. this request is based on a way to avoid black borders from the source without changing to HD resolutions if we want to use 16:9 aspect ratio. thank you for reply, regards, melody www.espiritosanto.ccps: i liked off air message on external output, nice.
v3 will include some more widescreen output resolutions such as 720x405 and 640x360
Rank: Guest
Groups: Guests
thank you very much martin, this aditional resolutions will be apreciated. if is possible, try to add 864x480 and 1024x756 best regards, melody www.espiritosanto.cc
