Hardware Compatibility
Blackmagic Intensity Pro & Canon Vixia HF r600 Not Working
You have been a member since:: 9/13/2015(UTC) Posts: 15 Location: California
I'm trying to add my new Cannon camera as an input into vMix. When I try I don't see it as an option in the drop down.
http://prntscr.com/92hw68
I've installed the Capture cards and the software drivers
http://prntscr.com/92hwgm http://prntscr.com/92hwkq
and I've charged my Cannon cameras overnight so the battery is charged. I've also tried all the slots for the HDMI cable, restarted windows multiple times to no avail.
Anybody have any ideas?
Thanks!!
Looking at your first screen shot, the Blackmagic Intensity Pro isn't recognized by vMix.
What happens when you run one of the Blackmagic programs such as Media Express? Does it recognize the Intensity Pro and display video?
If it does, shutdown vMix then try restarting vMix and see if the Intensity Pro is on the drop down after the restart.
Joined: 3/7/2012(UTC) Posts: 2,659  Location: Canada Thanks: 33 times Was thanked: 509 time(s) in 478 post(s)
@ vmixnewbie
When dealing with Blackmagic Design capture devices, the first order of business in trouble shooting is to insure that the product works with "Media Express" (Blackmagic Design's software that gets installed with the installation CD of your product or maybe now it's a download) since that is what Blackmagic will want to know before they offer any kind of support. If it doesn't work there, then you have an issue with the card and/or BMD. If it works there, but not with vMix, it might be a setting somewhere and you can trouble shoot that. In any event, something appears to be amiss with your installation since it doesn't look like the 'Intensity Pro' isn't recognized by vMix yet (it should appear in the dropdown), which likely means it's not recognized by your computer yet and wont work with "Media Express" either. I am not up to date on the current installation procedures for the 'Intensity Pro', but I would look into that and insure that you have all the tools and software they include to make sure the product works for you properly.
Joined: 8/2/2013(UTC) Posts: 1,083   Location: Fairhope, Alabama USA Thanks: 569 times Was thanked: 201 time(s) in 167 post(s)
Driver in your screen shot looks like a 2007 version.
- Tom
 1 user thanked sinc747 for this useful post.
Joined: 10/13/2012(UTC) Posts: 1,162  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
Go to the BM support site and download the latest Desktop Video app. This includes the latest drivers. Once installed you have to configure the card using the Desktop Video Utility. Then confirm you can see the feed in Media Express. Finally add as an input to vMix.
 1 user thanked ask for this useful post.
ask wrote:Go to the BM support site and download the latest Desktop Video app. This includes the latest drivers. Once installed you have to configure the card using the Desktop Video Utility. Then confirm you can see the feed in Media Express. Finally add as an input to vMix.
Thanks for your help. I've tried like crazy to find the app you mentioned. I ended up downloading Blackmagic_Desktop_Video_Linux_10.3 (1).7.tar, from https://www.blackmagicdesign.com/support which I couldn't open unless I downloaded 7 zip which extracted the files but my computer won't run any of the files in the subsequent folders. I've never heard of *.deb files.
http://prntscr.com/92qxib and http://prntscr.com/92qxot (there are many more screenshots I could have taken)
Not sure what to do with these?
I don't know why you can't find the newest drivers for the intensity pro capture card. I've attached the folder that I was able to extract but I'm not sure where to go from here.
Any ideas??
Joined: 2/24/2014(UTC) Posts: 45   Location: Maine, USA Thanks: 26 times Was thanked: 14 time(s) in 12 post(s)
 1 user thanked DYosua for this useful post.
DYosua thank you so much! This is quite the process!
So according to @ask I then need to somehow get the desktop video utility. I appreciate both of your support here! :)
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
I am using a Blackmagic Intensity Pro card and it is working with no problems. What card slot in your PC have you got your card plugged in to, it should be plugged in to a PCIEX1 or a PCIEx16 graphics slot for it to work a be recognised. If you have installed your card in to a PCI slot it won't work. See pic below 2 pictures pic 1 is of the BM control panel of my card and pic 2 is of a motherboard and the card slots where the BM card should be in Red arrows. Len56 attached the following image(s):  Pic 1.jpg (38kb) downloaded 0 time(s). Pic 2.jpg (869kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
Len56 wrote:I am using a Blackmagic Intensity Pro card and it is working with no problems.
See pic below 2 pictures pic 1 is of the BM control panel of my card and pic 2 is of a motherboard and the card slots where the BM card should be in Red.
Thanks Len56. I will look at my slots and try to determine what they're called. I'm not sure it says but thanks for letting me know about that! :)
@Len56 it looks like I'm using the PCIEX1 slots in my computer. I'll keep working at it. Thanks for your thoughts!
Thanks Ice Stream for this info. I read through them all. I found it interesting what they said in the first link about the bios as well as the 3rd link about the command lines to type into the command prompt. I bought 3 of these capture cards off ebay and none of them are recognized by my system so far. I've tried all 3 of the cards in all 3 PCIe slots and nothing. I think my only hope is to try these comman line prompts?
Ahh, That's worrying me that you said you bought your 3 cards from ebay and you can't get any of them to work, they may be bad cards. The only thing I can think of is to buy a card from a proper dealer and see if it works.
