Feature Requests
need to seperate livestream overlays from recording
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
hi Martin,
i have put this issue forward sometime ago but it keeps comming up in my feature requests list during live production: the ability to show an overlay like a banner or ticker on the stream but not on the recording.
currently stream and recording are one and the same setting in the options for the overlays: so its one or the other: show and record or no show.
seperating these options by seperating the livestream / output from the recording would enable a clean recording of a live event that can be edited afterwards. I can not unedit an overly once its recorded.
Who else is running into this problem ? Is there a work around? last livestream I seperated mixing and recording vs streaming to provide a clean recording of an event. but this requires an extra vmix machine, etc etc. for simple streaming and recording ine vmix machine should suffice.
greetings stefan
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
This is called a "Clean Feed" and we have a need for this also.
We also need this as an "external" output.
It is in my next list of features request. :-)
Joined: 11/15/2010(UTC) Posts: 99  Location: Jamaica Thanks: 23 times Was thanked: 17 time(s) in 14 post(s)
h2video.nl wrote:hi Martin,
greetings stefan I second that, we really need something like that.
Joined: 11/7/2013(UTC) Posts: 66 Location: Netherlands
Thanks: 21 times Was thanked: 9 time(s) in 8 post(s)
Hello Stefan, Under settings >outputs >uncheking on wich overlay your live bug is.  Is this what you'd like to achieve? If you uncheck overlay 1 on recording for example your live bug isn't showed on the recording if it's pushed to air as overlay 1. Greetings, Iason
@ TVIason
That works for those that have the option to stream from 'External 2'(vMix 4K and above), and perhaps not the answer that h2video.nl wants to hear as I think the original request is to differentiate the 'Recording' from 'External' for general use across all vMix editions. However, as noted, this is a higher end feature and requires an upgrade to vMix 4k or Pro to successfully accomplish, and I suspect not likely to be a granted request.
Feature Requests
