Truthsforliving
#1 Posted : Friday, October 30, 2015 2:32:33 AM(UTC)
Truthsforliving
Can someone please tell me why I can record a presentation and the audio is exactly like it should be for playback but I can't hear anything through my headphones during the process of recording?
What do I need to do? It must be simple....
Speegs
#2 Posted : Friday, October 30, 2015 4:21:39 AM(UTC)
Speegs
Check the settings and then Audio Outputs.
Make sure Headphones is set to the audio device you are using for your headphones.
That is a story within itself, your headphones could be usb, bluetooh, in a different sound card.
If that doesn't get you on the right path, we would need more information about how the headphones are connected.
Truthsforliving
#3 Posted : Friday, October 30, 2015 8:55:10 AM(UTC)
Truthsforliving
Thank you for your response.
I have done all of that already and have also reset the entire program to defaults and still no sound. Remember, the sound is there in the finished product. I just cant hear any sound during the process with or without headphones.
I have checked the audio inputs and pc settings as well but since I can hear audio from any source except vmix (while recording) I seem to think it is a software setting too simple to see
r@wisla
#4 Posted : Friday, October 30, 2015 9:20:41 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
Could you show us a screenshot of your vMix audio mixer?
Maybe you pressed [s] (solo) button somewhere...?
sinc747
#5 Posted : Friday, October 30, 2015 1:49:18 PM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
One of the simplest ways to monitor your audio during streaming/recording is to actually connect the headphones to a speaker jack on your PC and, in vMix, direct the Headphone Audio to that Windows Audio Device.
Setting up headphones to monitor audio through a separate mixer can be difficult. At is it is for me. ;)
- Tom
