Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hi!
I wanted to get some shots over a phone (Android or in last case iOS) and receive on vMix.
There are many apps for surveillance.
Do you use any in particular that you recommend and is possible to get a url for vmix?
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
If you mean still shots, use for example Dropbox to automatically upload photos to a photo folder and share that with the PC running vMix.
If you mean live video, search around in the forum as it smartphones as cameras has been discussed many times (and there is currently no built in support for that in Vmix). I might be wrong, but I think some people have used apps that send RTMP feeds that can be received by vMix.
Joined: 10/29/2015(UTC) Posts: 1 Location: Universite de Bordeaux
solution is software DroidCam on phone and vMix station
you loock for in Play Store
after install and config you phone is seam webcam for vMix by wifi
Joined: 12/27/2012(UTC) Posts: 5,481  Location: Belgium Thanks: 314 times Was thanked: 1017 time(s) in 835 post(s)
Tioneb wrote:solution is software DroidCam on phone and vMix station
can confirm this :-)
hmm, ok and do I need the paid version? How do I add on vMix? RTSP?
(with the lite I can see video using the app but I can't insert on vMix, I only see the Camera "DroidCam Source 3" which is pink)
