rrpro
#1 Posted : Thursday, October 29, 2015 8:43:23 AM(UTC)
rrpro
Hi!
I wanted to get some shots over a phone (Android or in last case iOS) and receive on vMix.
There are many apps for surveillance.
Do you use any in particular that you recommend and is possible to get a url for vmix?
richardgatarski
#2 Posted : Thursday, October 29, 2015 8:56:50 AM(UTC)
richardgatarski
If you mean still shots, use for example Dropbox to automatically upload photos to a photo folder and share that with the PC running vMix.
If you mean live video, search around in the forum as it smartphones as cameras has been discussed many times (and there is currently no built in support for that in Vmix). I might be wrong, but I think some people have used apps that send RTMP feeds that can be received by vMix.
Tioneb
#3 Posted : Thursday, October 29, 2015 12:34:12 PM(UTC)
Tioneb
solution is software DroidCam on phone and vMix station
you loock for in Play Store
after install and config you phone is seam webcam for vMix by wifi
#4 Posted : Thursday, October 29, 2015 2:10:31 PM(UTC)
can confirm this :-)
rrpro
#5 Posted : Thursday, October 29, 2015 3:21:15 PM(UTC)
rrpro
hmm, ok and do I need the paid version? How do I add on vMix? RTSP?
(with the lite I can see video using the app but I can't insert on vMix, I only see the Camera "DroidCam Source 3" which is pink)
