ClementN
#1 Posted : Saturday, October 10, 2015 1:17:31 PM(UTC)
ClementN
Romania
We have 2 ASUS laptops almost identical. (ROG, i7, Win 8.1 etc).
The only difference is the graphic card (one is GTX 970M and one is GTX 870M -- latest drivers)
The problem is vMix have big differences for the rendering time ( 1 ms and 37 ms ) when tested without any input. The situation is worst if there are camera inputs.
Can anyone please advice where to look to check the cause for that big difference ?
What can be wrong on the 37ms one ? Is it possible for the graphic card to be damaged in any way ? Can I check that ?
Thank you for your support,
Clement
richardgatarski
#2 Posted : Saturday, October 10, 2015 1:59:09 PM(UTC)
richardgatarski
Was thanked: 297 time(s) in 250 post(s)
have you checked in the performance tab that vMix is using the nVidia card/s?
ClementN
#3 Posted : Saturday, October 10, 2015 2:12:02 PM(UTC)
ClementN
Romania
Yes. I did, Richard.
Always nVidia
#4 Posted : Saturday, October 10, 2015 7:29:43 PM(UTC)
Was thanked: 506 time(s) in 475 post(s)
@ ClementN
How do the cards differ in a stress test such as "FurMark"?
http://www.ozone3d.net/benchmarks/fur/
I would think that both cards should perform reasonably well, but perhaps the 870 is somewhat defective or malfunctioning and that just might show up in the stress test.
ClementN
#5 Posted : Sunday, October 11, 2015 4:47:55 AM(UTC)
ClementN
Romania
Thank you very much, Ice.
I did the tests ( fullscreen, dynamic camera, fullHD) but as I didn't make this test before I am not sure if something is wrong or not.
There are differences between the 2 cards
870M -- FPS average: 17 ; temp: 87 ; score: 1165
980M -- FPS average: 38 ; teamp: 67 ; score: 2635
I think that the FPS 17 is too low but I am not sure if it is ok or not.
Any advice ?
richardgatarski
#6 Posted : Sunday, October 11, 2015 8:38:01 AM(UTC)
richardgatarski
Clement, not sure wich laptop you have, but the ROG's can usually have the Graphics card overclock. If so, may be it's not enabled on the 980M
ClementN
#7 Posted : Tuesday, October 13, 2015 2:07:14 PM(UTC)
ClementN
Romania
Thank you, Richard, Ice.
The only solution was the reinstall of Win 8.1 with the latest mVidia driver.
Don't know the cause of the problem.
