Feed/aspect ratio is being stretched
Joined: 10/8/2015(UTC) Posts: 10 Location: Cordova,Ak
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
I am streaming using 640x360 in all my settings and yet my feed is being stretched. What am I missing?
Rank:: Advanced Member
Joined: 8/2/2013(UTC) Posts: 1,083   Location: Fairhope, Alabama USA Thanks: 570 times Was thanked: 201 time(s) in 167 post(s)
What is the aspect ratio of embed code on the website where you stream is viewed?
- Tom
640x360....I stream to YouTube.
Its being stretched on the local output as well.
Well...
What about your camera input settings. What is the setting for Camera Settings -> General -> Aspect Ratio?
What is the setting for Settings -> Display -> Aspect Ratio?
Can you share your YouTube vid?
You can view at ASLN.net/livecity
Looking at your YT videos, there is definitely a fly in the ointment.
Share about your camera(s). Brand. Model. Resolution options. Frame rate options. What resolution and frame rate is/are they set to? Just wondering if maybe the camera is sending a different resolution (like 640x480).
 1 user thanked sinc747 for this useful post.
Joined: 3/7/2012(UTC) Posts: 2,662  Location: Canada Thanks: 33 times Was thanked: 509 time(s) in 478 post(s)
@ ASLNTV
Looks to me like the camera "Normal" is SD 640x480 (or possibly 720x576) and you are stretching it by setting your "Output" to 640x360 in vMix, if I understand you correctly that it is being stretched in your "Output" window. It would also appear that YouTube is receiving an SD 4:3 signal with the stretched image. So, as Tom suggests, you may have to provide more info from top to bottom from cameras and input settings to output and streaming settings to get to the bottom of your issue.
I'm just using Logitech webcameras, the 270 models. I will double check that the output resolution is the same as my cameras. Pretty sure they are.
