ASLNTV
#1 Posted : Thursday, October 8, 2015 9:22:30 AM(UTC)
ASLNTV
I am streaming using 640x360 in all my settings and yet my feed is being stretched. What am I missing?
sinc747
#2 Posted : Thursday, October 8, 2015 5:54:48 PM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
What is the aspect ratio of embed code on the website where you stream is viewed?
- Tom
ASLNTV
#3 Posted : Thursday, October 8, 2015 6:55:13 PM(UTC)
ASLNTV
640x360....I stream to YouTube.
ASLNTV
#4 Posted : Thursday, October 8, 2015 8:25:24 PM(UTC)
ASLNTV
Its being stretched on the local output as well.
sinc747
#5 Posted : Thursday, October 8, 2015 9:48:38 PM(UTC)
sinc747
Well...
What about your camera input settings. What is the setting for Camera Settings -> General -> Aspect Ratio?
What is the setting for Settings -> Display -> Aspect Ratio?
ASLNTV
#6 Posted : Thursday, October 8, 2015 9:57:19 PM(UTC)
ASLNTV
Normal on both
sinc747
#7 Posted : Thursday, October 8, 2015 11:46:50 PM(UTC)
sinc747
Can you share your YouTube vid?
ASLNTV
#8 Posted : Thursday, October 8, 2015 11:57:23 PM(UTC)
ASLNTV
You can view at ASLN.net/livecity
sinc747
#9 Posted : Friday, October 9, 2015 2:28:53 AM(UTC)
sinc747
Looking at your YT videos, there is definitely a fly in the ointment.
Share about your camera(s). Brand. Model. Resolution options. Frame rate options. What resolution and frame rate is/are they set to? Just wondering if maybe the camera is sending a different resolution (like 640x480).
ASLNTV on 10/9/2015(UTC)
#10 Posted : Friday, October 9, 2015 5:47:46 PM(UTC)
@ ASLNTV
Looks to me like the camera "Normal" is SD 640x480 (or possibly 720x576) and you are stretching it by setting your "Output" to 640x360 in vMix, if I understand you correctly that it is being stretched in your "Output" window.
It would also appear that YouTube is receiving an SD 4:3 signal with the stretched image. So, as Tom suggests, you may have to provide more info from top to bottom from cameras and input settings to output and streaming settings to get to the bottom of your issue.
ASLNTV
#11 Posted : Friday, October 9, 2015 5:50:57 PM(UTC)
ASLNTV
I'm just using Logitech webcameras, the 270 models. I will double check that the output resolution is the same as my cameras. Pretty sure they are.
