Greg
#1 Posted : Friday, June 15, 2012 5:47:36 PM(UTC)
Greg
I am trying to record the final output to a file but the audio always stops before the video. Regardless of how long the video is there will be no audio the last little bit of the video. This happens when you try to use the video in Adobe premiere, after effects, or media encoder. When I play it in the preview window of windows 7 the audio will play but not when you import the video into premiere for editing.
Has anyone else seen this sort of problem?
#2 Posted : Saturday, June 16, 2012 8:35:52 AM(UTC)
Was thanked: 4788 time(s) in 1643 post(s)
Hi Greg,
What format and settings did you use for the recording?
Greg
#3 Posted : Saturday, June 16, 2012 9:11:11 AM(UTC)
Greg
So far I have only found one setting that will generate an avi file that windows media player or premiere will play. With the default settings I could not view or import the file. The current settings are:
Settings/Decoders/mpeg 2 video: MainConcept(adobe2)Mpeg video decoder
Use vMix is checked
Settings/Decoders/mpeg audio: MainConcept(adobe2)Mpeg video decoder
Settings/audio/Default Audio Renderer: Default DirectSound Device
On the recording setup tab
Codec: DV Video Encoder
File Format: AVI
Audio Device: vMix Virtual Audio Capture
Audio Format: 44100 Hz 16 Bit 2 Channels
I am running windows 7 64bit and Vmix is the latest version but it still has an issue with the audio not recording correctly due to the 44Hz vs. the 48Hz issue. When I bring the audio into the computer on the mic input it is very choppy and scratchy. You can’t understand what is being said. If you bring the audio in through one of the camera inputs the audio is ok.
I haven’t been able to use the program on a live event thus far but would like to before purchasing it.
Any help would be greatly appreciated.
Luc Henrion
#4 Posted : Saturday, June 16, 2012 9:19:58 AM(UTC)
Luc Henrion
Just my 2 cents: I think you could benefit from using an external audio card, both in quality and reliability...
melody
#5 Posted: : Saturday, June 16, 2012 9:44:11 AM(UTC)
Rank: Guest
Groups: Guests
hi greg,
to avoid audio issues in w7 x64, make sure if your device supports 48khz recording. right click in the audio icon, on the right of start bar, go to "Recording Devices", double click your device and in advance tab select 48khz.
however, make sure too if your drivers are the latest.
regards,
melody
www.espiritosanto.cc
Greg
#6 Posted: : Saturday, June 16, 2012 11:49:11 AM(UTC)
Greg
Thanks Melody, I tried that but still have the same results.
another odd thing that is occuring is if I choose mpeg rather than avi the video playes very fast for several seconds and the audio playes normal. When the video hits the last frame it shows the last frame of video but the audio will continue to play normal.
melody
#7 Posted : Saturday, June 16, 2012 2:03:10 PM(UTC)
Rank: Guest
Groups: Guests
what audio device are you using at the moment?
Greg
#8 Posted : Sunday, June 17, 2012 9:15:38 AM(UTC)
Greg
The sound card is listed as Conexant 20672 SmartAudio HD
melody
#9 Posted : Sunday, June 17, 2012 10:11:29 AM(UTC)
Rank: Guest
Groups: Guests
a similar issue in Windows XP has been posted on vmix forum. take a look at the link below...
http://forums.vmix.com.a...t.aspx?g=posts&t=378
seems that vmix have some compatbility issues with conexant devices (2 devices at once). maybe martin can investigate better.
regards,
melody
#10 Posted : Sunday, June 17, 2012 10:53:48 AM(UTC)
Hi Greg,
Can you double check you have downloaded and installed the latest version on this page:
http://www.vmix.com.au/download.aspx
There was an audio issue in v2 on some computers, but it has been fixed.
Greg
#11 Posted : Sunday, June 17, 2012 9:53:46 PM(UTC)
Greg
I do have the latest version installed. I tried to find the version in the software but could not. The reason I know, is that I can now choose 2 rolls for the imputs. If I remember correctly version 2 did not have that in it.
Thanks for all your help.
Greg
#12 Posted : Tuesday, June 19, 2012 5:24:46 PM(UTC)
Greg
Do you have a program for a clean uninstall being I have the latest version? I did uninstall the version 2 before installing the version 3 but I am sure there were some registry entrys that were left. I know the audio was there because I had adobe flash live media encoder make a file. When I checked it the audio was there for the full video.
Greg
ELCHAPIN
#13 Posted : Tuesday, June 19, 2012 6:02:57 PM(UTC)
ELCHAPIN
Hola
Me soluciono muchos Problemas de audio y por solo $$49.00 Dolares
un super sonido equalizado . has tu testealo tu
Cero problems con este USB
http://www.amazon.com/Be...005EHILV4/ref=pd_cp_MI_2 .
NO MAS PROBLEMAS EN WIN 7-64 Perfecto
Greg
#14 Posted : Wednesday, June 27, 2012 9:18:49 PM(UTC)
Greg
Do you have any other suggestion which may correct this problem?
Greg
melody
#15 Posted : Thursday, June 28, 2012 5:59:56 AM(UTC)
Rank: Guest
Groups: Guests
hi greg,
you can use Revo Unistaller to completly remove vmix from your computer, including registry entries, folders, etc... then, restart your machine and install vmix. it may be sufficient.
regards,
melody
#16 Posted : Thursday, June 28, 2012 6:08:08 AM(UTC)
Hi Greg,
Uninstalling vMix is not necessary to ensure it is the latest version as long as it says 7.3.0.86 in the title bar it will be the latest version.
If I am understanding correctly the audio and video record fine and playback correctly in windows media player except that in adobe premiere that last few seconds of audio are missing?
If so you could try converting the AVI file to another format using the various converter tools out there or alternatively just make sure each recording is 30 seconds longer than you need.
Greg
#17 Posted : Tuesday, July 3, 2012 8:05:02 PM(UTC)
Greg
As I checked the one file I recorded, it is longer than a few minutes. On a 59 minute file the audio stopped around the 46 minute mark. Any other suggestions on how to correct this in VMix? I will try a converter tool but if I purchase this program and start using it on a regular basis. I will need it to record the file correctly so I am not out any more time trying to get a final file.
Greg
#18 Posted : Wednesday, July 4, 2012 11:56:02 PM(UTC)
Hi Greg,
I have not been able to re-create the issue so far so it looks like a unique issue with that particular computer unfortunately.
I suggest trying some other codec besides the DV Video Encoder to see if that helps.
