duck130883
#1 Posted : Saturday, September 26, 2015 7:56:55 PM(UTC)
duck130883
Hello, can somehow be set for each input source of the sound ? For example, to input 1 and 2 using sound input from input 1 Input 3 and Input 4 using sound input 4 , and so on .
Thank you in advance for your reply
#2 Posted : Saturday, September 26, 2015 9:17:41 PM(UTC)
@ duck130883
AFAIK there is no button or setting to do that kind of patching, but there are probably a couple of different ways to accomplish that task.
Depending on the nature of your 'Inputs', you can look into using "Triggers" to turn the 'audio' ON and OFF.
Alternatively, you can look into using "MultiView" inputs, hiding 'Input 3' behind 'Input 4' kind of thing.
I hope that helps some.
duck130883
#3 Posted : Sunday, September 27, 2015 5:22:36 AM(UTC)
duck130883
It probably will not be for me a good deal . My case : I'll run livestream from 4 cameras and need to Camera 1 and 2 using the sound from the Camera 1. Camera 3 and 4 using the sound from the camera 4. It would ideal if the individual camera inputs to be able to choose the sound settings from another audio source already open input.
tdurhamjr
#4 Posted : Sunday, September 27, 2015 8:41:02 AM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
When you add a camera, you can see an audio source drop down. You can select which audio should go with that camera. So in that way you can match up particular audio to each camera. You can also add the audio from the camera as an Audio Input and then you would have 2 different Audio inputs and you can use triggers to switch the audio inputs.
Tim
tdurhamjr attached the following image(s):
Assigning audio to camera input.jpg (140kb) downloaded 0 time(s).
Similar Topics
Zoom sound input is mute (General Discussion)
by Simsyuk 3/4/2025 5:33:39 PM(UTC)
