Guru
#1 Posted : Thursday, September 10, 2015 12:10:37 PM(UTC)
Guru
I'm rendering videos from AfterFX for overlays and bugs. I've used HuffYUV and Lagarith so far (Magic YUV doesn't like alpha channels).
When I import these into vMix, even when I check the "this video has an alpha channel" box, the alpha channel isn't spotted or used.
When I drop them back into AfterFX, the alpha is there for sure.
Q: Is this normal in version 16? I notice that Lagarith *used* to work around version 9 :-)
For now I'm rendering as PNG sequences, which work, but it's a more painful workflow.
Any answers on if this should/shouldn't work, and what I might be doing wrong would be much appreciated, thanks :D
#2 Posted : Thursday, September 10, 2015 12:37:17 PM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
It should all still work but it looks like Lagarith has gone through a lot of changes
since I looked at it last and it appears to have broken a few things.
Best to encode using QuickTime Animation or QuickTime PNG as these will work fine with alpha in vMix.
Guru
#3 Posted : Thursday, September 10, 2015 12:42:10 PM(UTC)
Guru
Thanks for the tip Martin :-)
Do you have a 'known good' version of Lagarith that should still work?
