#1 Posted : Monday, September 7, 2015 11:32:20 AM(UTC)
Not sure if this is a design change or a bug...
In previous editions, right clicking a special effects multiview input would provide options for the upper most layer of the 'MultiView' input.
This was very handy for opening and editing XAML Titles used in that input (in my case upstream keys like scoreboard overlays).
In vMix 16.0.0.68 there are no other options other than "Create Virtual Input" which makes it more difficult to 'edit on the fly' when you have to search through all your inputs to find the right one to edit. Not the "end of the world", but it was a feature I became very accustomed to using and if at all possible, would be nice to have back.
#2 Posted : Tuesday, September 8, 2015 3:17:58 AM(UTC)
Was thanked: 4721 time(s) in 1617 post(s)
You will have to submit this as a feature request as the ability to see a menu from a multiview input is actually
a bug and was never intended to work that way.
Would not be possible to bring it back in the current form either, so you will need to propose a way to
display multiple input menus in your feature request.
#3 Posted : Tuesday, September 8, 2015 9:55:48 AM(UTC)
@ admin
I tend to find good ways to work with what I've got, than to ask for different or "better" ways of doing something but I'll see what I can come up with.
It will likely be a little more complex than the un-intended but useful 'bug' that has been fixed, but ideas can be like that.
Kelvin
#4 Posted : Tuesday, September 8, 2015 11:44:24 AM(UTC)
Kelvin
I have used that "bug" as well. It was handy.
