Replay error with AJA Io4k and Decklink 4K
 Getting this when trying to add 1080p60 sources from both io4k and/or decklink 4k
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
1080p60 sources are usually really 1080p59.94 so make sure when adding the cameras that 1080p59.94 is selected and that 59.94 is also selected in instant Replay.
Or alternatively if this is a PC source set both to 60
Tried this, and still same error but mentioning 59.94 instead.
It's a PC source and they are both set to 60.
Please try the latest vMix 16 downloadable from our web site. If the problem still appears, click Send Error Report.
Martin vMix
Still having the same issues even trying 59.94 and 60. We are also running the latest up-to-date version of vmix16
Error report has also been sent
Thanks, just checked the report and it says the camera was added as 60p. Please change this to 59.95p instead when adding the camera and send an error report if the problem still occurs.
Martin vMix
Actually, I think I see what might be happening now. Should have a fix soon.
Awesome, thanks - will check it out tomorrow. We're just proud of ourselves for identifying two bugs in two weeks ;)
