I seem to be having an issue with full screen output.
I have a alpha MOV file (32bpp PNG image container) I am running with vmix, and the preview and output panels appear to be running smoothly, but the full screen output of the output panel is very rough and glitchy. I haven't tried to record it as yet, and not sure if that is the way to go. Thinking perhaps of recording the view I see with my phone and uploading it if you need to see it.
The video seams to run alright in VLC & Vegas pro. I should also state this is version 16.0.0.47 running on Windows 10.
Seems to be a problem also with another MPG file I previously had no issues with. Both of these files I have used previously on vmix15 and windows 7 without problems.
I'm not saying this is a vMix issue, as it could very well be a Windows 10 issue.
Hoping to have some settings adjustments recommended to fix the problem.
It shoudl also be known I am running an EVGA\nVidia Geforce GTX 770 video card in this system.
madness wrote:I seem to be having an issue with full screen output.
It shoudl also be known I am running an EVGA\nVidia Geforce GTX 770 video card in this system. Here is what I'm seeing...
Playing with my problem further, I tried using vmix to record using MP4 and FFMPEG, and where I would see the image jitter on the full screen output, it actually freeze frames in the recording.
I'm assuming this is a windows 10 issue, but it could also be vMix on 10. It's pretty much unusable at this point.
Joined: 1/13/2010(UTC) Views messages in topic : 5,311  Location: Gold Coast, Australia Was thanked: 4711 time(s) in 1615 post(s)
madness wrote:Playing with my problem further, I tried using vmix to record using MP4 and FFMPEG, and where I would see the image jitter on the full screen output, it actually freeze frames in the recording.
I'm assuming this is a windows 10 issue, but it could also be vMix on 10. It's pretty much unusable at this point. Could you please email us a sample recording along with the log files? You can now go to vMix settings -> About and click Send Support Report for the log files but I will need to see the recording as well. Note: I have tested both vMix 15 and 16 on Windows 10 without issue, so it could be a driver or corruption issue. Based on user reports of other Windows 10 issues, installing from scratch usually fixes it. Thanks
admin wrote:madness wrote:Playing with my problem further, I tried using vmix to record using MP4 and FFMPEG, and where I would see the image jitter on the full screen output, it actually freeze frames in the recording.
I'm assuming this is a windows 10 issue, but it could also be vMix on 10. It's pretty much unusable at this point. Could you please email us a sample recording along with the log files? You can now go to vMix settings -> About and click Send Support Report for the log files but I will need to see the recording as well. Note: I have tested both vMix 15 and 16 on Windows 10 without issue, so it could be a driver or corruption issue. Based on user reports of other Windows 10 issues, installing from scratch usually fixes it. Thanks Didn't have time to do this today, but yes, when I get a moment, I will certainly do this. Thanks for the response.
I'm assuming this is a windows 10 issue, but it could also be vMix on 10. It's pretty much unusable at this point. Could you please email us a sample recording along with the log files? You can now go to vMix settings -> About and click Send Support Report for the log files but I will need to see the recording as well. Note: I have tested both vMix 15 and 16 on Windows 10 without issue, so it could be a driver or corruption issue. Based on user reports of other Windows 10 issues, installing from scratch usually fixes it. Thanks The log file you want... Is this the log file that is created with the recorded file? If so, a 10 second recording and it's log file are provided in the following link. https://drive.google.com...NWRNOVk/view?usp=sharing
Madness, It looks like the graphics card is dropping a lot of frames, what is the render time like? Try resetting vMix to default settings from Settings -> Default
Render time in vegas pro? Seems normal to me. Not sure how I would measure this. I'll give default a try.
Render time in vMix ;-) Found in the status bar, lower left corner.
 1 user thanked ovinas for this useful post.
Alright. I have reset it to default settings, and I currently have 6 inputs set up. 1. Blue animated background mov 2. US flag animation mov 3. Virtual input of Blue animated background with US flag animation on first overlay 4. C920 camera rotated 90 degrees (portrait) so as to have a virtual position camera that moves top to bottom. 5. virtual input of blue animated background with c920 input as first overlay scrolled to bottom camera position. 6. virtual input of blue animated background with c920 input as first overlay scrolled to mid camera position.
When I add inputs beyond this, I start to see the jittering. I was able to run this an more prior to Windows 10 on vMix 15 and windows 7, prior to the upgrade from 6 to 18GB of memory.
My system currently is: ASUS P6T mobo 18GB Corsiar memory Intel core i7 920 quad core processor running @2.8GHz EVGA Geforce GTX660 FTW w/ ACX 2GB GDDR5 192 Bit Dual-Link DVI-I DVI-D HDMI DP SLI Ready Graphics Card (02G-P4-3063-KR) Toshiba 256GB SSD primary HDD Corsair 128GB SSD secondary HDD WD 1T HDD 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels Inateck PCI-E to USB 3.0 5-Port PCI Express Card SteelSeries Apex Gaming Keyboard Logitech M570 Wireless Trackball
Additional info I forgot to include... FPS is 31 Render time is 32ms CPU is 28-32%
Actual CPU usage appears to be running~50% across all 8 threaded cores. When I close vMix, the CPU drops to between 1-3% usage.
Ok, it sounds like a potential CPU issue with the C920, could you try everything without that camera added and see what results you get?
Basically, depending on the driver the C920 can cause problems with other devices in the system including dropped frames, high cpu and other issues.
Martin vMix
 1 user thanked ask for this useful post.
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
madness,
You say you are using an ASUS motherboard, are you using the motherboard software that comes with the motherboard like EPU-6 Engine, if you are that will be controlling your CPU speed, I have an ASUS motherboard with this software installed and I found that if the EPU-6 Engine is set up on the Auto setting vMix is very sluggish so I set the EPU-6 Engine to high performance mode and then vMix works perfectly.
I've just created a separate thread for this discussion. Best I can tell this appears to be a C920 issue rather than Windows 10, as I have seen it in the past on some machines.
The C920 can cause all sorts of strange CPU and GPU spikes due to a bad driver and then work perfectly fine on other systems.
The Logitech C920 driver uses a lot of CPU when you allow it's auto settings; right-light and auto-focus. If you disable these things then the C920 puts much less load on the host. The Xsplit guys did a blog post about this: https://www.xsplit.com/b...-with-xsplit-broadcasterThis is one reason why the C930e and BCC950 models are more appealing to me. Michael
That driver is dated Oct-2012. So it looks unchanged except for that it's shown as compatible with Windows 10.
Len56 wrote:madness,
I am using an ASUS mobo, but installed a clean Win 10 OS, with no Asus software. Just let windows 10 do it's thing for all drivers except the Nvidia drivers of which I installed direct from NVidia. Been busy the last few days, so I did not see the responses since my last post. I will look for and install the new C920 driver. Are there new win 10 drivers for the MS Lifecam and Logitech c270 webcams also? I'll have a look. I've also been looking at a new system as the i7-920 is going on 8 years old and growing long in the tooth compared to the new skylake systems. That said, Budget may cause me to hold off on that upgrade path.
Just went to take a look at that new Logitech driver/software...
Software Version: 2.80.853.0a Post Date: 26-OCT-2012 OS: Windows 8, Windows 10 File Size: 73Mb
That supports most all the Logitech products. The Lifecam studio currently only has drivers for XP-Windows 8. No Windows 10 specific driver as yet.
admin wrote:Ok, it sounds like a potential CPU issue with the C920, could you try everything without that camera added and see what results you get?
Martin vMix Modified a few settings. My main output is now limited to 1280x720 and 29.97 fps I have 10 inputs set up. 4 of these are USB webcams... 1x Lifecam studio 1920x1080@ 24fps yuy2 2x c270 1280x720 24fps RGB24 1x c920 1920x1080 29.97 fps RGB24 I again have 3 virtual animated backgrounds with the c920 as an overlay using different portions of the camera. My stats are 30 fps, render time of 19-30ms, and cpu at 39-45%, although windows reports cpu at 68-75%. I notice an occasional dropped frame, but much more stable than before. Without any camera inputs, and only the original blue animation, the flag animation, and then a virtual blue animation with the flag as an overlay, the stats were as follows. FPS 31 render 7ms cpu 20% actual windows CPU 27% with that config and the addition of the c920 for a total of 4 inputs, the following... fps 31 render 13ms cpu 28% Actual cpu 42% From what I can tell in device manage, I am running the 10-22-2012 driver for windows. I am about to re download the latest and verify results.
