vMix 16 Recording meter issue
When recording, there is no bar meter shows the recording in the audio mixer. Is there a solution?
Groups: Guests
Next to the 'Record' button, click on the 'cog' to configure the recording settings, and tick the 'Audio' box if it is not ticked.......
With the same settings in v15 no problem. but in v16.0.0.48 no display in recording meter. And now it is repaired by martin in v16.0.0.50. admin wrote:An update to vMix 16 (16.0.0.50) has been uploaded.http://www.vmixhd.com/download/vmix16preview.exeChanges/Fixes: * MultiCorder now supports MP4 and FFMPEG * MPEG-2 recording tab is now hidden if the codec is not available (such as on Windows 10) * Fixed Recording/External audio meter not working * Fixed bug when loading presets with non-0 audio balance * Improved merge layer sorting * Fixed text rendering overlap in template graphics (to print these, click Save Graphic to save an image that can be printed) * Added VC-3 presets to match the various bitrate/resolution/framerate options I'm interested in hearing feedback on if the Merge effect is any better for the scenarios that have been discussed. Fades on non-merging layers I still think are important for the majority of use cases, but hopefully the ordering solves some issues that have been reported. I'm sorry my bad english
