Playing Video Clips on 2 seperate audio cards
Hello
Is it possible to play video clips on say one soundcard and a different clip on a different audio card?
Thanks Carlos
Joined: 6/4/2013(UTC) Posts: 308 Location: Germany Thanks: 1 times Was thanked: 57 time(s) in 49 post(s)
Here is the issue I'm facing...
My external mixer's output (which includes my microphones and other feeds) is fed into VMix via an audio interface
My video clips are played natively in VMix
Our Output is SDI to an ATEM switcher
I would like the video clips in VMix to pass through my external mixer (so I can control volume as my sound guys do not want to have to mess with the video switcher's control over the computer) and be able to pass through my External Output (SDI)
Hope this is clear
Setting up an aux output as a mix minus and reading the vMix documentation will do the job.
Joined: 2/18/2014(UTC) Posts: 1,837 Location: Stockholm
Thanks: 144 times Was thanked: 297 time(s) in 250 post(s)
And in addition to what ovinas says, you need to use analog (not USB) audio interfacing, otherwise you will face delay induced by USB drivers.
(google "mix minus" if you don't know what that is)
