vMix - no video only black screen
Hello, i got now vMix and i trired to setup the livestream, but there appears no video, only a black screen appears. The vifdeo file is .mp4.
Hope to get a fast feedback.
Are you trying to play a mp4 file and this doesn't work? Or is the video playing and it won't stream? A more structured description with more information would help a lot.....
Hi, i add as a Input a .mp4 file but on the screen there is only a black screen, and if i stream there is also only a black screen.
On the desktop with VLC the video works.
Do you have any solution?
Does the video play? Did you try some other videos?
yes i tried alao another video but also a mp4 one. Does the format .mp4 works on vMix?
Yes, and normally without any problems. Try to reinstall.
@ navee
Does it play on "Windows Media Player"?
 I reinstalled and also installed the new update bu still black screen, only the logo can be seen on the live preview, but if i put the rtmp on VLC its showing me nothing. Could someone help please?
Does your video clip play in VLC or Window Media Player?
If not, the it is your problem. Try a different clip.
VLC will show you all about the technical details of the media.
Michael
Hi, yes the video plays normal on the VLC player.
Hope for a solution, thanks
Joined: 1/13/2010(UTC) Posts: 5,336  Location: Gold Coast, Australia Was thanked: 4736 time(s) in 1625 post(s)
Please install the latest graphics card drivers for your computer. It looks like the Windows basic graphics driver is installed rather than the one from the manufacturer. (Nvidia, AMD or Intel).
Martin vMix
Hello, i opened ones a thread already, nut now i fixed a bit.
I had the problem that nothing appears when i click on stream but now i installed video codecs which one user advised "K-Lite Codec x64" now the sound appears and a image which i use as a channel logo a small one in a corner.
But there is still the problem that only a black screen appears , sound works logo also.
Is there or could be there another problem?
Hope to get a fast and positive feedback ;)
sorry, for the new thread.
I installed the video codecs for my server, now i can see all the images when the streaming starts, also the soun works.
But there i still no video, is there any solution please?
Hope for a feedback thanks
admin wrote:Hi,
Martin vMix
Hi, im now downloading the driver kit, but the video works fine on the VLC Player only on VMix there is a black screen in the preview screen is also a black screen.
I will update after the driver kit
i installed the latest drivers, but still not working is there any other solutions?
Could you please provide a download link for one of the non working videos?
This is the video which i try to stream : i downloaded the video, its a mp4. file in 1080HD but i also tried a 480p one cause i got the vmix free one, but still not works. youtube link : youtubeI also tried to add colours its working, but no video. Is there any solution please?
@ navee
What software did you use to download? That might be the source of your issue... (the file plays fine for me from my download)
