Hardware Compatibility
Support for G2020 & G3258 CPUs?
I'm building some low cost mini PCs for a church and was wondering if I could pull off a 4 HD camera setup with VMix and Intel G2020 or G3258 Dual Core processors with 16GB RAM and a GTX750Ti. Any ideas? I will not be using any effects whatsoever.
Thanks Carlos
Thanks: 5 times Was thanked: 18 time(s) in 18 post(s)
Dear Carlos,
I will not advice it. The G2020/3258 are low level CPU. You can use it for SD signal smoothly, but not for HD signal
If you don't make streaming a want a low cost unit, go for an AMD FX 6300 at least If you have more, go for an I5
Rgds
C.
Thanks!
Decided on i5-4690 CPU anyway. Smooth so far.
