carlosowusu
#1 Posted : Wednesday, July 22, 2015 6:44:08 AM(UTC)
carlosowusu
I'm building some low cost mini PCs for a church and was wondering if I could pull off
a 4 HD camera setup with VMix and Intel G2020 or G3258 Dual Core processors with 16GB
RAM and a GTX750Ti. Any ideas? I will not be using any effects whatsoever.
Carlos
Charssay
#2 Posted : Thursday, July 23, 2015 5:34:53 AM(UTC)
Charssay
Dear Carlos,
I will not advice it.
The G2020/3258 are low level CPU.
You can use it for SD signal smoothly, but not for HD signal
If you don't make streaming a want a low cost unit, go for an AMD FX 6300 at least
If you have more, go for an I5
Rgds
C.
carlosowusu
#3 Posted : Tuesday, August 4, 2015 5:24:22 AM(UTC)
carlosowusu
Thanks!
Decided on i5-4690 CPU anyway. Smooth so far.
