Hi Martin,
how does the timecode work in title newshd2? I have to make a live of a match of football and I would like to use the title newshd2 as timecode for the game,
Best regards and thanks for your help,
vmix its great
Giacomo from france
In the Title Editor for NewsHD2 you can put the following as text into the TitleTime box to turn the time into a countdown:
{0:6:00PM|hh:mm:ss}
The above will set the text to number of hours/minutes/seconds left until 6PM
This code can be used in any of the text items, not just in NewsHD2
Somewhat related, but perhaps more of a feature request, I would like to have a scoreboard with integrated time clock and possibly a secondary and tertiary timer (ie shot clock or penalty clock). I used a work-around for this in my broadcasts (sample here: http://www.justin.tv/golivenow/b/313621607) by using XNote Stopwatch as a screen capture PiP overlay and my own scoreboard graphics, the issue is it uses up all 4 overlays since each element is its own graphic, also with the new graphical interface of v3 I can see that it will be somewhat more difficult to quickly distinguish between the thumbnails which all look the same at that size (perhaps a toggle switch for filename/graphic thumbnail would help to eliminate confusion on similar looking graphics).
Thanks: 8 times Was thanked: 46 time(s) in 23 post(s)
IceStream wrote:Somewhat related, but perhaps more of a feature request, I would like to have a scoreboard with integrated time clock and possibly a secondary and tertiary timer (ie shot clock or penalty clock). I used a work-around for this in my broadcasts (sample here: http://www.justin.tv/golivenow/b/313621607) by using XNote Stopwatch as a screen capture PiP overlay and my own scoreboard graphics, the issue is it uses up all 4 overlays since each element is its own graphic, also with the new graphical interface of v3 I can see that it will be somewhat more difficult to quickly distinguish between the thumbnails which all look the same at that size (perhaps a toggle switch for filename/graphic thumbnail would help to eliminate confusion on similar looking graphics). One alternative approach (if internet connection is available) is to create a web application consisting of: 1. flash visualisation (swf) of score/time hosted on a web server. this can be added as an input in vMix 2. user interface for score/time input, for example a php page hosted on the same web server The result is something like this (possible to enter teams, time, etc): http://www.bkventspils.l...ska_cina_uzvar_roanne_chThis way you have full control over the visualisation and any information you want to display dinamically.
