HighViewSport
#1 Posted : Tuesday, July 14, 2015 7:23:35 PM(UTC)
HighViewSport
Hi Martin,
Can I request for vMix 16 some kind of recording recovery feature. I typically situation is when we accidentally remove a storage device removal or a power failure while recording in a production. This would be a great piece of mind.
Yes, I still have a backup recording via my Atomos Ninja connected to output but having vMix do a this would be great too.
Cheers Bryan
GeorgeR
#2 Posted : Tuesday, July 14, 2015 7:43:22 PM(UTC)
GeorgeR
Was thanked: 30 time(s) in 28 post(s)
HighViewSport wrote:
Hi Martin,
Cheers Bryan
Hi Byron,
You can set vMix to record anywhere from 1 minute to 60 minutes (1-5-10-15-20-30-60) which will give you a new file for the recording session selected. You can also set vMix to record straight through without any breaks.
Cheers!
~George
HighViewSport
#3 Posted : Wednesday, July 15, 2015 9:00:06 PM(UTC)
HighViewSport
Thanks George,
I see that option but I was really meaning the ability for vMix to fix a corrupted file due to a power failure. Sorry, I was not really specific about the corrupted file part.
I really only want one full length file and if it's corrupted then I have a big issue. Hope Martin can get vMix to fix the corrupted file.
Cheers Bryan
ask
#4 Posted : Wednesday, July 15, 2015 9:26:05 PM(UTC)
ask
Was thanked: 199 time(s) in 181 post(s)
Bryan. if you use MPEG TS as your recording format you should limit issues in these circumstances. See also here: http://www.vmixhd.com/he...tTolerantRecordings.html
