Mesmer
#1 Posted : Monday, July 13, 2015 9:40:12 AM(UTC)
Mesmer
Good day every one.
I have a Windows 8 pro. Intel i7 possessor, 36g of ram and a Titan graphic card.. But I haven't been able to get a image using the SC510N4 SDI.. Are there a recomendable settings? Help please..
thanks 1 user thanked Mesmer for this useful post.
IceStream on 7/13/2015(UTC)
#2 Posted : Monday, July 13, 2015 10:05:17 AM(UTC)
Rank:: Advanced Member
@ Mesmer
Might be a driver conflict somewhere (read thise threads)...
http://forums.vmixhd.com....aspx?g=posts&t=3188
http://forums.vmix.com.a....aspx?g=posts&t=3707
http://forums.vmix.com.a....aspx?g=posts&t=3818
Also, what camera(s) or inputs are you connecting?
A few more details about your set-up and/or settings that you've tried might help to narrow down the issue.
Mesmer
#3 Posted : Monday, July 13, 2015 10:11:40 AM(UTC)
Mesmer
Thank you Ice for your support.
I'm using 2 canon xa25, sdi out put 1080i
Mesmer
#4 Posted : Monday, July 13, 2015 10:18:07 AM(UTC)
Mesmer
It does reconize the capture card and its channels, is just that the image freezes or goes black
#5 Posted : Monday, July 13, 2015 10:39:15 AM(UTC)
I've added a few more related links, not sure if you've had a chance to read through them and/or confirm that you have removed conflicting drivers and have the most up to date drivers.
Do the cameras get recognized in any other programs?
Mesmer
#6 Posted : Monday, July 13, 2015 11:06:00 AM(UTC)
Mesmer
Yes ice.. I don't have any other capture card or drivers that could conflict with this one... I don't think is a Vmix issue, I did tried it with other programs and it was giving me the same problem... I do have the latest drivers.. Could I just be setting the capture chanel in resolution not supported (1080i 59.94i)? I don't know...
richardgatarski
#7 Posted : Monday, July 13, 2015 11:31:28 AM(UTC)
richardgatarski
have you turned on SDI out in the Camera's (XA25 menu) setting?
Mesmer
#8 Posted : Monday, July 13, 2015 11:37:52 AM(UTC)
Mesmer
@Richard... yes. sdi is turn on.. But now I'm not sure what would be the right fps?
richardgatarski
#9 Posted : Monday, July 13, 2015 5:33:30 PM(UTC)
richardgatarski
have you been able to check that there is a video signal coming out of the camera? Eg using a SDI monitor or another video input card. Always best to eliminate possible causes from the source, in your case the camera.
Do you have any other SDI source to test with?
Try disabling HDMI out in the camera, set its video recording format non mp4, frame rate to 60i, SDI out to 1920i, power camera off, then on. Start vMix from scratch (or clear preset), add a new Input with the 1920 resolution and 60i.
In my experiences with the XA25 and SC510 cards no matter what frame rate/reslution at the camera, at least something else than black is shown, no freezing (but we are PAL, eg 50p)
With vMix we don't change any other settings than frame rate (eg 50i) and resolutiom (eg 1920×1080). Go through and check all four inputs.
If that does not do it, then try on another PC. If that fails, your card might be bad.
Mesmer
#10 Posted : Tuesday, July 14, 2015 7:37:39 AM(UTC)
Mesmer
@ Richard.. Thank you for the advice.. I really appreciate it.
