Joined: 1/13/2010(UTC) Posts: 5,320  Location: Gold Coast, Australia Was thanked: 4721 time(s) in 1617 post(s)
vMix 16 is in development and will include some powerful new features, particularly for audio. The first beta is expected to be released in a couple of weeks time!
Please keep posting feature requests over in the Feature Requests forum. If you have any questions about the features below, please post them here.
=========================== Audio
* ASIO support for multiple audio inputs and outputs * Noise Gate effect * 10 band EQ effect
Scripting
* New scripting support in 4K and Pro editions. * Write your own code and attach it to a keyboard key or trigger. * Code can be created as either VB.NET or as a text list of API functions to call * Scripts can be run from the API
Shortcuts and Triggers
Completely revamped shortcuts system. * Easy add multiple shortcuts to a single key and select the order to run them. * Disable individual shortcuts as needed * Import and Export sets of shortcuts and generate printable keyboard diagrams for them * New OnOverlayIn and OnOverlayOut triggers available * Context sensitive editor: will only show applicable settings for each shortcut function and will provide helpful information when a value is required.
Recording
* New FFMPEG recording option with a number of built in presets (MP4, MPEG-2, VC-3 and ProRes) * Higher quality recording options added to Instant Replay (150Mbps and 200Mbps) * Logs now saved in separate folder
Streaming
* DaCast and StreamingChurch.tv added to built in providers with more to come
* Added support for many more RTMP stream types as inputs * API support for selecting Input by Name (first matching name found)
Martin vMix
 3 users thanked admin for this useful post.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
Looking forward to the Scripting macros. What we need is physical keyboard shortcuts in some way for the web interface. For both the "Switcher" page and the "macros" page in some combined way. Now we have the "slo-mo operator" using the Vmix PC. We need a way for the TD to run the switcher with physical keys and these new macros, from something like an X-Keys, on another cheap web-browser PC or even Android tablet. Touchscreen functionality is great, we just need real buttons to press. Midi support in a way like this would be great start: http://forums.vmix.com.au/default.aspx?g=posts&t=1779Thanks Steve
 1 user thanked stevespaw for this useful post.
Hi Guys,
As mentioned this is not a thread for feature requests, vMix 16 is already a lock. I have moved the feature requests posts to the relevant threads in Feature Requests.
Thanks,
Martin vMix
Thanks: 14 times Was thanked: 4 time(s) in 4 post(s)
"* New FFMPEG recording option with a number of built in presets (MP4, MPEG-2, VC-3 and ProRes)"
The MP4 (FFMPEG) recording option have CBR?
Thanks Martin
Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
When a beta will be available to download? I can not wait to try it, especially for ASIO support with a mixer Presonus FireStudio Project. Thanks for your work.
Some exciting news on two additional features coming to vMix 16!
* MIDI support! This has been a strong feature request, so it is going to be integrated into shortcuts for buttons and faders in the first release and expanded later to support feedback such as light indicators and motorized faders on supported hardware.
* Merge Transition For example if you have a camera fullscreen in Preview and in a double box multiview on Output, clicking the Merge transition button will Pan and Zoom the inputs position automatically to the new multiview position.
You really have to see it to believe it, so we'll post a demo video soon.
Martin vMix
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
Very cool feature Martin!
Is there also an appropriate shortcut function key that will be assigned for this specific transition?
That is great Martin! Looks like the stuff done on high end productions by the ABC/Fox etc....
ASIO and MIDI!!! Can't wait to test this. I'm open for beta testing... ;-)
 1 user thanked ovinas for this useful post.
Oh whow! Both features are wonderful news - thanks :)
Looking at the demo Merge seems to do a pan, zoom, and dissolve. Will it be possible to not include the dissolve part?
I also agree with Richard on the 'Fade' (it distracts somewhat from the overall 'zoom' effect, but it's not a deal breaker). The other question I have is does it matter which 'layer' or overlay channel is being "merged" to? I see this as being a very useful effects tool for Skype calls and/or multiple person panel discussions, will it work equally well for all channels or inputs?
It merges matching inputs in the Preview and Output and then dissolves the rest. This is important because some unique layers will be on the of others, so you won't see the merge unless they are dissolved while the matching inputs are merged.
Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
Awesome ..We do that effect with virtual set..mixing 2 or 3 virtual sets in one.but is a lot more work. I can't wait ,thats is what i want long tine ago..the first wirecast have it...and i like it....so now in vmix ...wonderful.
Test equipment ready to go... waiting for download... #ASIO #MIDI ovinas attached the following image(s):  10.jpg (108kb) downloaded 10 time(s).You cannot view/download attachments. Try to login or register.
Hello Martin, I am available for beta test anytime for support ASIO. Thanks.
admin wrote: The first beta is expected to be released in a couple of weeks time!
Any update... is more than 2 weeks.... We are desperate .... JOe1378
Sorry about that, due to the decision to add MIDI support in this release, it is going to take just a little bit longer for the first beta!
Martin vMix
