Ferrari
#1 Posted : Sunday, March 25, 2012 3:23:28 PM(UTC)
Ferrari
Hi Martin,
I'm able to capture VoD from my site, but not live streaming. For VoD I use, for example, this connection string rtmp://webtv.estream.it/estream_vod/mp4:flancini.mp4 and wMix works correctly. If I need to capture live video the string is different, for example in FMLE my rtmp string is 'rtmp://webtv.estream.it/live' and the connection string is 'live', I tried several combinations of strings like 'rtmp://webtv.estream.it/live:live' or else, but I wasn't able to let it works.
Can you help me to find the correct string?
Giorgio
thanks 1 user thanked Ferrari for this useful post.
angelo78 on 9/30/2012(UTC)
#2 Posted : Sunday, March 25, 2012 9:31:13 PM(UTC)
Was thanked: 4674 time(s) in 1609 post(s)
Is there a web site where that stream is currently working?
That way I can do some tests to compare.
Note that many public live streams block access by anything other than the intended web site.
melody
#3 Posted : Monday, March 26, 2012 8:31:44 AM(UTC)
Rank: Guest
Groups: Guests
hi martin,
i cant use our live rtmp stream as input in vmix:
streamer:rtmp://www.espiritosanto.cc:1945/ies_tv
file:ies_tv.flv
what is the correct syntax?
what about to add some swf player support to vmix? or maybe a dedicated feature that enables user to introduce information in available bars below:
- SWF Player (url, skin support and direct player controll) it would be nice to add self players on vmix;
- Streamer;
- File;
- Flashvars (all vars as possible);
regards,
melody
#4 Posted : Monday, March 26, 2012 8:52:32 AM(UTC)
Could you set this live stream up on a website so I can compare?
If it works fine on a web site that will help narrow down any problems.
melody
#5 Posted : Monday, March 26, 2012 8:56:53 AM(UTC)
Rank: Guest
Groups: Guests
this live stream is 24h available on http://www.espiritosanto.cc/culto-em-directo
i edited last post after your reply.
regards,
melody
#6 Posted : Monday, March 26, 2012 11:03:41 AM(UTC)
URLS should be:
rtmp://www.espiritosanto.cc:1945/ies_tv/ies_tv
rtmp://www.espiritosanto.cc:1945/ies_tv/ies_tv_180p
etc
I have tested these in vMix 2012 v2
Ferrari
#7 Posted : Tuesday, March 27, 2012 4:26:54 AM(UTC)
Ferrari
Hi Martin,
live stream is avaliable on www.estream.it/live.aspx.
Giorgio
melody
#8 Posted : Tuesday, March 27, 2012 5:18:19 AM(UTC)
Rank: Guest
Groups: Guests
thanks martin, espiritosanto.cc urls are now working here too.
so, if you want to try another urls go to inforventura.blogspot.com/p/area-do-web-stream.html and you have another several live streams to compare.
in case of GOD TV (US, UK and Australia) or TBN, JCTV, Smile of a Child and Church Channel we have the same streamer with diferent live streams (diferent .flv files).
how can we use these diferent streams on vmix?
regards,
melody
