Hi Martin,
I'm able to capture VoD from my site, but not live streaming. For VoD I use, for example, this connection string rtmp://webtv.estream.it/estream_vod/mp4:flancini.mp4 and wMix works correctly. If I need to capture live video the string is different, for example in FMLE my rtmp string is 'rtmp://webtv.estream.it/live' and the connection string is 'live', I tried several combinations of strings like 'rtmp://webtv.estream.it/live:live' or else, but I wasn't able to let it works. Can you help me to find the correct string?
Thanks Giorgio
 1 user thanked Ferrari for this useful post.
Joined: 1/13/2010(UTC) Posts: 5,316  Location: Gold Coast, Australia Was thanked: 4718 time(s) in 1616 post(s)
Is there a web site where that stream is currently working? That way I can do some tests to compare.
Note that many public live streams block access by anything other than the intended web site.
Martin vMix
Rank: Guest
Groups: Guests
hi martin, i cant use our live rtmp stream as input in vmix: streamer:rtmp://www.espiritosanto.cc:1945/ies_tv file:ies_tv.flv what is the correct syntax? what about to add some swf player support to vmix? or maybe a dedicated feature that enables user to introduce information in available bars below: - SWF Player (url, skin support and direct player controll) it would be nice to add self players on vmix; - Streamer; - File; - Flashvars (all vars as possible); regards, melody www.espiritosanto.cc
Could you set this live stream up on a website so I can compare? If it works fine on a web site that will help narrow down any problems.
Martin vMix
Rank: Guest
Groups: Guests
URLS should be:
rtmp://www.espiritosanto.cc:1945/ies_tv/ies_tv rtmp://www.espiritosanto.cc:1945/ies_tv/ies_tv_180p
etc I have tested these in vMix 2012 v2
Rank: Guest
Groups: Guests
thanks martin, espiritosanto.cc urls are now working here too. so, if you want to try another urls go to inforventura.blogspot.com/p/area-do-web-stream.html and you have another several live streams to compare. in case of GOD TV (US, UK and Australia) or TBN, JCTV, Smile of a Child and Church Channel we have the same streamer with diferent live streams (diferent .flv files). how can we use these diferent streams on vmix? regards, melody www.espiritosanto.cc
