Joined: 1/13/2010(UTC) Posts: 5,204  Location: Gold Coast, Australia Was thanked: 4465 time(s) in 1558 post(s)
15.0.0.63
* RTMP Stream username/password was not being set for multi bitrate streams * AJA inputs can now be added even if cameras have not yet been connected * MultiView Output time displays now show time remaining instead of position * Fixed Preview MultiView Audio Meter bug when input was not in first 8 inputs * Fixed error when clicking near zero on playback speed bar
15.0.0.65
* Fixed bug when handling multiple stream keys separated by ; * Fixed "Object reference" error when adding a Replay Input from a preset that has the replay speed saved as something other than 100% * Fixed error when opening a Replay Input configured to use Output but with a different format to current session * Fixed Stream Input issue with Transport Stream UDP dropping audio after a number of days
15.0.0.66
* Improved accuracy of current time when displayed in Title. * Fixed bug where ticker may have caused MultiView titles to stop updating
15.0.0.68
* Fixed title of Replay B not always matching Replay A
* Fixed incorrect icon in the replay controller button used to swap cameras
* Improved timing of Photos and PowerPoint transitions. When pausing/playing or restarting the timer will reset to 0 again.
15.0.0.72
* Added checks for graphics card issues that may cause fullscreen output to freeze * Fixed error when recording with Matrox VS4 I-Frame codec * Fixed RGB issue with HDMI input on AJA cards
15.0.0.73
-Fixed decoding bug with Replay when dragging the position to the end quickly -Fixed bug when clicking Loop button in Replay controller while replay is running -Fixed incorrect function on Previous/Next buttons under Preview
15.0.0.78
-Removed some of the error messages that are displayed when streaming/recording: --"Recording has not been configured" replaced with recording confirmation window --"Invalid URL" when clicking Stream without configuring the stream will now go directly to the settings window --"MultiCorder has not been configured" replaced with opening the MultiCorder window directly
-Added the following shortcuts: StartStopRecording StartStopStreaming StartStopExternal StartStopMultiCorder StartMultiCorder StopMultiCorder
-List input can now be added empty, allowing videos to be added later
-Disabled network optimisation algorithm (Nagle) that may slow down API and Web Interface responses
 3 users thanked admin for this useful post.
15.0.0.81
-Fixed Rec.709 colour shift issue when using interlaced HD cameras and interlaced output. -Fixed XAML saving issue with Presets and vMix Title Designer where the ticker length would no longer auto-adjust when adding more text.
15.0.0.85
* Fixed last frame bug with some XAML storyboard animations * Changed cut behaviour on interlaced frame rate. Will no longer cut between upper and lower fields. * Support for RGB32 format when using newer Blackmagic devices. -To use this option select the Camera dropdown option in vMix that has the cards product name (such as Intensity Pro 4K) do not use the Decklink Video Capture/Blackmagic WDM Capture options -Select RGB32 as the Video Format when using RGB HDMI sources such as desktops
* WMV Streaming maximum clients changed to 50 from 25 * Streaming API 2.0 support added
15.0.0.86
* Made the Image auto update feature more robust. Instead of just monitoring for file modification, will also update if file is renamed, replaced or moved.
15.0.0.87
Fixed issue with RGB HDMI sources with the Kona LHi
15.0.0.88
* Latest version of vMix Social is now bundled with vMix * Fixed index bug when opening MultiCorder settings after starting and stopping a recording
