#1 Posted : Wednesday, March 11, 2015 5:47:04 AM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
15.0.0.63
* RTMP Stream username/password was not being set for multi bitrate streams
* AJA inputs can now be added even if cameras have not yet been connected
* MultiView Output time displays now show time remaining instead of position
* Fixed Preview MultiView Audio Meter bug when input was not in first 8 inputs
* Fixed error when clicking near zero on playback speed bar
thomas on 3/11/2015(UTC), madness on 3/12/2015(UTC)
#2 Posted : Friday, March 13, 2015 2:24:09 AM(UTC)
15.0.0.65
* Fixed bug when handling multiple stream keys separated by ;
* Fixed "Object reference" error when adding a Replay Input from a preset that has the replay speed saved as something other than 100%
* Fixed error when opening a Replay Input configured to use Output but with a different format to current session
* Fixed Stream Input issue with Transport Stream UDP dropping audio after a number of days
#3 Posted : Friday, March 13, 2015 6:29:50 AM(UTC)
15.0.0.66
* Improved accuracy of current time when displayed in Title.
* Fixed bug where ticker may have caused MultiView titles to stop updating
#4 Posted : Wednesday, March 25, 2015 10:32:04 AM(UTC)
15.0.0.68
* Fixed title of Replay B not always matching Replay A
* Fixed incorrect icon in the replay controller button used to swap cameras
* Improved timing of Photos and PowerPoint transitions.
When pausing/playing or restarting the timer will reset to 0 again.
jip on 3/25/2015(UTC), madness on 3/26/2015(UTC)
#5 Posted : Wednesday, April 1, 2015 5:54:32 AM(UTC)
15.0.0.72
* Added checks for graphics card issues that may cause fullscreen output to freeze
* Fixed error when recording with Matrox VS4 I-Frame codec
* Fixed RGB issue with HDMI input on AJA cards
madness on 5/21/2015(UTC)
#6 Posted : Thursday, April 2, 2015 6:44:39 PM(UTC)
15.0.0.73
-Fixed decoding bug with Replay when dragging the position to the end quickly
-Fixed bug when clicking Loop button in Replay controller while replay is running
-Fixed incorrect function on Previous/Next buttons under Preview
#7 Posted : Monday, May 18, 2015 8:42:07 PM(UTC)
15.0.0.78
-Removed some of the error messages that are displayed when streaming/recording:
--"Recording has not been configured" replaced with recording confirmation window
--"Invalid URL" when clicking Stream without configuring the stream will now go directly to the settings window
--"MultiCorder has not been configured" replaced with opening the MultiCorder window directly
-Added the following shortcuts:
StartStopRecording
StartStopStreaming
StartStopExternal
StartStopMultiCorder
StartMultiCorder
StopMultiCorder
-List input can now be added empty, allowing videos to be added later
-Disabled network optimisation algorithm (Nagle) that may slow down API and Web Interface responses
thanks 3 users thanked admin for this useful post.
PFBM on 5/19/2015(UTC), madness on 5/21/2015(UTC), Bardos on 6/3/2015(UTC)
#8 Posted : Friday, June 5, 2015 6:38:13 PM(UTC)
15.0.0.81
-Fixed Rec.709 colour shift issue when using interlaced HD cameras and interlaced output.
-Fixed XAML saving issue with Presets and vMix Title Designer where the ticker length would no longer auto-adjust when adding more text.
#9 Posted : Tuesday, June 30, 2015 2:16:23 AM(UTC)
15.0.0.85
* Fixed last frame bug with some XAML storyboard animations
* Changed cut behaviour on interlaced frame rate. Will no longer cut between upper and lower fields.
* Support for RGB32 format when using newer Blackmagic devices.
-To use this option select the Camera dropdown option in vMix that has the cards product name (such as Intensity Pro 4K)
do not use the Decklink Video Capture/Blackmagic WDM Capture options
-Select RGB32 as the Video Format when using RGB HDMI sources such as desktops
* WMV Streaming maximum clients changed to 50 from 25
* Streaming API 2.0 support added
madness on 6/30/2015(UTC), Thremir on 7/1/2015(UTC)
#10 Posted : Wednesday, July 1, 2015 2:21:08 AM(UTC)
15.0.0.86
* Made the Image auto update feature more robust.
Instead of just monitoring for file modification, will also update if file is renamed, replaced or moved.
#11 Posted : Thursday, July 2, 2015 3:37:15 AM(UTC)
15.0.0.87
Fixed issue with RGB HDMI sources with the Kona LHi
madness on 7/2/2015(UTC), PFBM on 7/11/2015(UTC)
#12 Posted : Saturday, July 11, 2015 6:46:51 AM(UTC)
15.0.0.88
* Latest version of vMix Social is now bundled with vMix
* Fixed index bug when opening MultiCorder settings after starting and stopping a recording
