Feature Requests
Shortcut "send API" to control multiple systems
Thanks: 8 times Was thanked: 8 time(s) in 7 post(s)
In my sports productions I work with multiple vMix-systems and operators. Therefore I need an option to send API-commands from one system to another. (f.ex. operator 1 can start the replay play-out on machine 2 by using a shortcut on his machine 1)
It would be perfect to have a shortcut where you just type the API-URL into the value-field. So you can execute your shortcuts on more than one system.
Regards, Yannick
Joined: 11/8/2013(UTC) Posts: 87  Location: Bavaria, Germany Thanks: 6 times Was thanked: 19 time(s) in 10 post(s)
+1
Sounds good, great idea. We also work with two machines in the future and this feature will make it a lot easier to "communicate" between the different systems. The new instant replay makes it neccessary to work with an extra slow-mo operator for best results. With this feature the director is able to start clips from the instant replay system on his demand, just with a touch of a button and without talking to the operator. This will be a big plus in professional sports productions.
Regards Karsten
Feature Requests
