krassesPferd
#1 Posted : Tuesday, June 2, 2015 5:44:48 AM(UTC)
krassesPferd
Was thanked: 8 time(s) in 7 post(s)
In my sports productions I work with multiple vMix-systems and operators. Therefore I need an option to send API-commands from one system to another. (f.ex. operator 1 can start the replay play-out on machine 2 by using a shortcut on his machine 1)
It would be perfect to have a shortcut where you just type the API-URL into the value-field.
So you can execute your shortcuts on more than one system.
Yannick
Innomedia
#2 Posted : Thursday, June 4, 2015 3:29:33 AM(UTC)
Innomedia
Was thanked: 19 time(s) in 10 post(s)
+1
Sounds good, great idea. We also work with two machines in the future and this feature will make it a lot easier to "communicate" between the different systems. The new instant replay makes it neccessary to work with an extra slow-mo operator for best results. With this feature the director is able to start clips from the instant replay system on his demand, just with a touch of a button and without talking to the operator. This will be a big plus in professional sports productions.
Regards
Karsten
