Hardware Compatibility
New MacBook Pro with the AMD Radeon R9 M370X Processor ...worth getting ?
Hello I am not sure if I should go with the older Nvidia GeForce GT750M or with the latest model that comes with a •AMD Radeon R9 M370X Graphics (2GB GDDR5) Or how is the integrated Graphics Iris Pro on either machine worth just getting that one... I have the Aja 4K IO unit and want to make sure if upgrading to the latest MacBook pro (Bootcamp) is worth it... Currently I am using the Mid 2012 MacBookPro with the 650M Nvidia Card.
Thank you for your thoughts...
Rank:: Advanced Member
Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 37 time(s) in 31 post(s)
BigApple wrote:Hello I am not sure if I should go with the older Nvidia GeForce GT750M or with the latest model that comes with a •AMD Radeon R9 M370X Graphics (2GB GDDR5) Or how is the integrated Graphics Iris Pro on either machine worth just getting that one... I have the Aja 4K IO unit and want to make sure if upgrading to the latest MacBook pro (Bootcamp) is worth it... Currently I am using the Mid 2012 MacBookPro with the 650M Nvidia Card.
HI. vMix is for Nvidia GPU only if you want to get the full power from it :) Cheers, PFBM
Ohh what a bummer. I guess it has to do with the cuda that only nvidia has. I guess I will hold on to my old MacBook then. Thank you very much.
PFBM wrote:BigApple wrote:Hello I am not sure if I should go with the older Nvidia GeForce GT750M or with the latest model that comes with a •AMD Radeon R9 M370X Graphics (2GB GDDR5) Or how is the integrated Graphics Iris Pro on either machine worth just getting that one... I have the Aja 4K IO unit and want to make sure if upgrading to the latest MacBook pro (Bootcamp) is worth it... Currently I am using the Mid 2012 MacBookPro with the 650M Nvidia Card.
HI. vMix is for Nvidia GPU only if you want to get the full power from it :) Cheers, PFBM Where did you get that information? I read about many users who are using AMD videocards just fine?
PFBM wrote:http://www.vmixhd.com/supported-hardware.aspx
AMD cards are also supporting direct x, don't see why they would not work. I'm now assembling a machine with a R9 290x, will let you guys know how well it works :)
 1 user thanked Ittaidv for this useful post.
thank you so much... cant wait to hear back ... before I take the plunch
