BigApple
#1 Posted : Tuesday, June 2, 2015 9:23:34 AM(UTC)
BigApple
Hello
I am not sure if I should go with the older Nvidia GeForce GT750M or with the latest model that comes with a •AMD Radeon R9 M370X Graphics (2GB GDDR5)
Or how is the integrated Graphics Iris Pro on either machine worth just getting that one...
I have the Aja 4K IO unit and want to make sure if upgrading to the latest MacBook pro (Bootcamp) is worth it...
Currently I am using the Mid 2012 MacBookPro with the 650M Nvidia Card.
Thank you for your thoughts...
PFBM
#2 Posted : Tuesday, June 2, 2015 11:21:59 AM(UTC)
PFBM
Was thanked: 36 time(s) in 31 post(s)
BigApple wrote:
Hello
HI.
vMix is for Nvidia GPU only if you want to get the full power from it :)
Cheers,
PFBM
BigApple
#3 Posted : Tuesday, June 2, 2015 2:56:47 PM(UTC)
BigApple
Ohh what a bummer. I guess it has to do with the cuda that only nvidia has. I guess I will hold on to my old MacBook then. Thank you very much.
Ittaidv
#4 Posted : Tuesday, June 2, 2015 3:24:05 PM(UTC)
Ittaidv
PFBM wrote:
BigApple wrote:
Hello
HI.
Cheers,
PFBM
Where did you get that information? I read about many users who are using AMD videocards just fine?
PFBM
#5 Posted : Tuesday, June 2, 2015 5:07:14 PM(UTC)
PFBM
Ittaidv
#6 Posted : Wednesday, June 3, 2015 7:49:03 AM(UTC)
Ittaidv
PFBM wrote:
http://www.vmixhd.com/supported-hardware.aspx
AMD cards are also supporting direct x, don't see why they would not work. I'm now assembling a machine with a R9 290x, will let you guys know how well it works :)
thanks 1 user thanked Ittaidv for this useful post.
BigApple on 6/3/2015(UTC)
BigApple
#7 Posted : Wednesday, June 3, 2015 9:30:54 AM(UTC)
BigApple
thank you so much... cant wait to hear back ... before I take the plunch
