Joined: 4/19/2014(UTC) Posts: 64  Location: United States Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
I am tryng to connect a Sony PJ650v into vMix using the intensity Pro HDMI PCIe capture card. I've tried all the settings I can think of.
Can anyone lead me into the right direction with trouble shooting?
Thanks in advance!
Is it working with Blackmagic's Media Express?
ovinas wrote:Is it working with Blackmagic's Media Express? Negative. I just plugged in a BMD SDI 4K card and our RED Scarlet set to 1080p24 and it worked, but that is not a good test to solve the problem. Different camera, diferent PCIe slot, different card etc. Can the BMD intensity pro HDMI (not 4k card) operate on a 4 lane PCIe? The SDI card is on an 8 lane.
From the manual: "Intensity Pro is a PCI Express 1 lane card and is compatible with 1,4,8 and 16 lane PCIe slots."
If it's not working in Media Express it won't work in vMix.
