Insta Capture from Indytek: capture MXF, Prores,..
I just got an email from Indytek about their new software: instacapture. I'm in no way affiliated with the developers, but wanted to share this since it's really useful. I downloaded the trial, and must say it's amazing software to run next to vmix for recording. You can select vmix video and audio as sources, and record with this application. It allows for recording in mxf, mpeg, mov, prores,... You can even run 2 instances of this sofware to record in different codecs or containers at the same time. I did a testrun, and depending on the codec, it's really light on recourses. At 49$, it was a no brainer for us to buy this. More info: http://decklinkcapture.blogspot.in/
 1 user thanked Ittaidv for this useful post.
Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 37 time(s) in 31 post(s)
Ittaidv wrote:I just got an email from Indytek about their new software: instacapture. I'm in no way affiliated with the developers, but wanted to share this since it's really useful. I downloaded the trial, and must say it's amazing software to run next to vmix for recording. You can select vmix video and audio as sources, and record with this application. It allows for recording in mxf, mpeg, mov, prores,... You can even run 2 instances of this sofware to record in different codecs or containers at the same time. I did a testrun, and depending on the codec, it's really light on recourses. At 49$, it was a no brainer for us to buy this. More info: http://decklinkcapture.blogspot.in/ Hi ! Great idea !! Will it work with a vMix system with any capture card ? Cheers, PM
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ Ittaidv
I am curious about the software... The documentation is somewhat vague and sketchy, it appears to be more of a "automated playout system" than a multi-format "Recorder". Are you able to simultaneously 'Stream' and 'Record'?
It just takes the external audio and video output from vmix as an input. Works great, and no complex codes needed like in ffmpeg.
IceStream wrote:@ Ittaidv
Ice On the indytek website they also have a playout software and a webtv software indeed, that's how I found those guys. The playout software and the webtv software I never really tried. On their website there is no mention yet about this software, on the link I posted above there is a fully working demo though. The funy thing is that it even mentions vmix in the screenshot they made. I don't get it why they're not here to promote their products, many of us would find them useful.
Ittaidv wrote:I just got an email from Indytek about their new software: instacapture. I'm in no way affiliated with the developers, but wanted to share this since it's really useful. I downloaded the trial, and must say it's amazing software to run next to vmix for recording. You can select vmix video and audio as sources, and record with this application. It allows for recording in mxf, mpeg, mov, prores,... You can even run 2 instances of this sofware to record in different codecs or containers at the same time. I did a testrun, and depending on the codec, it's really light on recourses. At 49$, it was a no brainer for us to buy this. More info: http://decklinkcapture.blogspot.in/ It Works !!!!!!!! with Final Cut Pro X , Avid Media Composer , and so on !! OS X and Windows !! No need to transcode ! Great Stuff !! for 50 bucks its a bargain . Please Martin , can you talk to this guy and get this prog inside vMix as an option ? Best regards, PFBM
I haven't had a chance to thoroughly test... I find the navigation somewhat confusing. My initial attempts to record (MXF, DNxHD) were not successful as an error message was generated. Any guidance is gladly appreciated...
IceStream wrote:I haven't had a chance to thoroughly test... I find the navigation somewhat confusing. My initial attempts to record (MXF, DNxHD) were not successful as an error message was generated. Any guidance is gladly appreciated...
Ice I wil try it on our system tonight. I have no idea about the architecture of this software, it might be a missing codec or something. I wonder by the way if this software is fully legal, since some of these codecs should be licensed I thought :) For such a price I wonder if that's the case. If it's all legal, it would indeed be a nice addition to vmix, or just to have the same options internally built in. I just found out you can even record to vob files. The only advertised option I could not find back is the h264 with CUDA cceleration Also in the options are some streaming codecs, no idea how it works, since there is no documentation at all, but I'm certainl going to try this out as well.
Groups: Guests
You have been a member since:: 9/15/2013(UTC) Posts: 168  Location: Barbados Thanks: 14 times Was thanked: 14 time(s) in 13 post(s)
I just downloaded and did a small test, ...works ok so far....it even sees wirecast, and a few more similar software....It looks like a good program, but seems to be in a development stage......also has a very low CPU usage as well......could go a long way with low powered PCs using vMix...
I found that some functions are not working....don't know if this is because it is in demo mode.....but the little test I did, it worked ok
 1 user thanked Bardos for this useful post.
It works , really works. This weekend, i will test it on a 2 hour recording in prores or dnxhd. very strange recording in prores 422 mov on windows...... :) but it works :)
Cheers,
PFBM
Ice Tested most codecs and containers, and everything seems to be running smooth and without problems. Do you have these codecs installed on the system where you run it on?
Also I could not resist to open the .exe with notepad, and discovered it was built using medialooks. Everything seems properly licensed, so it looks like this is all legal :)
@ Ittaidv
I am pretty sure they are (between PremierePro and Resolve) although, perhaps I am mis-informed about how this 'stuff' works. I would have thought that 'Insta Capture', if licensed to use these codecs, would also have them in the download... In any event, I will try and do some further tests in the near future and hopefully get to the bottom of what happened in my preliminary testing.
UPDATE
Initial round of testing done. Tried the 25 different 'format' options available to me at 'Default' or basic 5M bitrate where applicable (+ a few more). All codecs worked except for a few: - MXF (VC3/DNxHD) - ASF (DVCPRO-HD)
Most are fairly high compression codecs and not suitable for my purposes. I was impressed by the quality of the MOV DNxHD file, but then again it was 90M bitrate and 20 times larger than most of the other files. (I would say very comparable to the AVI CineForm files I usually record with vMix, both in size and quality)
The MXF MPEG2 recordings came in second in my books from a quality standpoint with pretty good compression ratios (about 15% the size of the above MOV mentioned but 2.5 times larger than many of the others) (I would say comparable in size and quality to ts or mpg MPEG 2 recordings done in vMix)
Many of the files I found to be not compatible or cause issues with my NLE (PremierePro CS5),including the above mentioned MOV file. (vMix's ts and mpg files also give me PP CS5 problems and why I have adopted AVI files as My standard).
The most positive advantage I found with this software is that I far prefer the MP4 encoding of 'Insta Capture' over vMix's MP4 recording, both in terms of quality and CPU usage. vMix seems to struggle with it on my system with CPU usage up to 80% whereas Insta Capture encoding is comparable with most of the others between 30% and 40%.
All-in-all, 'Insta Capture' appears to be pretty good value for the money, especially if you 'need' or want those additional containers (like MXF), or if you are having issues with MP4 recordings from vMix. I will likely try to do some more extensive and prolonged tests before I make my final conclusions, but to this point, it is not a "Must have" for me just yet.
