apell
#1 Posted : Wednesday, May 27, 2015 1:45:40 PM(UTC)
apell
During the live stream, observe that the red color of the button stream turns in orange color, for a few seconds. This means that it is stopping the stream;
Thank you very much
Apell
#2 Posted : Wednesday, May 27, 2015 5:28:59 PM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
If the button is showing up as orange after a few seconds, it usually means the internet connection is not fast
enough for the bitrate you have selected, select a lower bitrate and see if that helps.
As a general rule of thumb, run a test on http://www.speedtest.net/ and take note of the upload speed
and make sure the bitrate is no more than 60-75% of that amount for best results.
For example if the speed test result is 2Mbps uploads, make sure the bitrate in vMix is 1.5Mbps or lower.
apell on 5/27/2015(UTC)
