During the live stream, observe that the red color of the button stream turns in orange color, for a few seconds. This means that it is stopping the stream; Thank you very much Apell
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
Hi, If the button is showing up as orange after a few seconds, it usually means the internet connection is not fast enough for the bitrate you have selected, select a lower bitrate and see if that helps. As a general rule of thumb, run a test on http://www.speedtest.net/ and take note of the upload speed and make sure the bitrate is no more than 60-75% of that amount for best results. For example if the speed test result is 2Mbps uploads, make sure the bitrate in vMix is 1.5Mbps or lower. Regards, Martin vMix
