Is it possible to switch ppt slides from another computer using the ip address?
Wondering whether it is possible to switch the slides of a ppt by using a corresponding computer when only using the web address given by vmix in the settings section?
Simple solution. Get a wireless powerpoint presenter such as a logitech. Try a low tech solution first rather than trying a difficult programming task.
Load the powerpoint into vmix then set up a web shortcut for 'nextitem' for input 'active.'
Joined: 1/5/2014(UTC) Posts: 26 Location: Sanford, NC
I use this all the time. I have my presenter use his laptop. He has the power point on it. I load vMix desktop capture on the laptop and choose the laptop in vMix desktop capture as an input. I then use the capture as an overlay. Works great!
Groups: Joined: 9/15/2013(UTC) Posts: 168  Location: Barbados Thanks: 14 times Was thanked: 14 time(s) in 13 post(s)
wkrasley wrote:I use this all the time. I have my presenter use his laptop. He has the power point on it. I load vMix desktop capture on the laptop and choose the laptop in vMix desktop capture as an input. I then use the capture as an overlay. Works great! I do that same and it works great....I see that as an input.
