Show image for few seconds on video API
I want to show a fading image for few seconds on a live stream (commercial ad) and remove it through API or XAMPL not from xMix interface.
Thank you
Set your commercials up as an input. Then call that input via the API or Keyboard shortcuts. Please read the HELP files as there is good documentation there on the method. Once you have done that come back to the forum for any further questions.
I created an input and gave it a shortcut key (A key). When I press the A key on keyboard, the ad input plays over the video. The API help says Quote:Parameters
Function
Specify a function to execute. This can be any of the functions provided for the Shortcuts feature.
So, I tried to use the API like this http://127.0.0.1:8088/API/?Function=A&Input=0 , but I got this message No suitable Function could be found. Please Advice Thank you
@ elshorbagy
"A" is not a Function Use "Fade" or "Cut"
so, how can I call the shortcut from API?
