elshorbagy
#1 Posted : Friday, May 15, 2015 6:50:22 AM(UTC)
elshorbagy
I want to show a fading image for few seconds on a live stream (commercial ad) and remove it through API or XAMPL not from xMix interface.
Thank you
ask
#2 Posted : Saturday, May 16, 2015 2:14:02 AM(UTC)
ask
Set your commercials up as an input. Then call that input via the API or Keyboard shortcuts. Please read the HELP files as there is good documentation there on the method. Once you have done that come back to the forum for any further questions.
elshorbagy
#3 Posted : Monday, May 18, 2015 9:07:59 AM(UTC)
elshorbagy
I created an input and gave it a shortcut key (A key). When I press the A key on keyboard, the ad input plays over the video. The API help says
Parameters
Function
Specify a function to execute.
This can be any of the functions provided for the Shortcuts feature.
So, I tried to use the API like this
http://127.0.0.1:8088/API/?Function=A&Input=0 , but I got this message No suitable Function could be found. Please Advice
Thank you
#4 Posted : Monday, May 18, 2015 3:25:55 PM(UTC)
@ elshorbagy
"A" is not a Function
Use "Fade" or "Cut"
elshorbagy
#5 Posted : Tuesday, May 19, 2015 5:31:46 AM(UTC)
elshorbagy
so, how can I call the shortcut from API?
elshorbagy
#6 Posted : Wednesday, May 20, 2015 7:08:15 AM(UTC)
elshorbagy
I found it
Add input
http://127.0.0.1:8088/API/?Function=OverlayInput1&Input=4
Remove input:
http://127.0.0.1:8088/API/?Function=OverlayInput1Off&Input=4
Thank you
