Hardware Compatibility
Testing the AJA Hi5-4K usb Converter
Joined: 1/5/2013(UTC) Posts: 36   Location: Jamaica Thanks: 102 times Was thanked: 3 time(s) in 3 post(s)
Joined: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4739 time(s) in 1626 post(s)
This is an SDI to HDMI converter. The USB is only there for configuration updates.
Joined: 7/9/2014(UTC) Posts: 9 Location: Grass Valley, CA
That is correct. The Hi-5 4K is a converter that will convert signals in line, it will not allow ingest into a computer. The Hi5 4K is a great way to get a quad link over SDI 4k signal converted to HDMI. We also offer a Ha-5 4K which takes a HDMI signal and converts it to 4 SDI for use with quad link 3g hardware. If you need to get 4 SDI inputs our Io4k Thunderbolt device is a great option. If you only need to get 2 inputs our ioXT thunderbolt option is a good one! Feel free to give us a call if you have any questions always feel free to give us a call or shoot us an email! Phone: +1-530-274-2048 or email: Sales@aja.com-Eric Norrell AJA Video Systems
Joined: 10/16/2014(UTC) Posts: 32 Location: San Jose, CA
Hi Eric,
Nice to have an AJA rep on the forums. I currently own the IO 4k box and using it with vMix successfully. I need more 2 more inputs. Is the IO XT supported by vMix as well?
Thanks, Mike
Yessir.
All of our current Kona and Io products use the same SDK.
There are some limitations around the ioXT however as it uses an older chip that cannot do independent channels.
the IoXT will let you do 2 inputs into vMIx they would just have to both be the same signal (IE 1080i5994 or 720p).
Thanks for using io4k!
