I am trying to use my canon r300 and panasonic dv102 camcorders with vmix via a ezcap.tv video capture device. I cannot get a picture with either one. Are there special settings I should use?
Both camcorders work from av port to tv. Vvmix sees the Excap card but no video signal. VMic works perfect with my lifecam webcam. It's jusu using the camcorders that I am questioning
can vmix be used with the dazzle capture device? It sees the device, but I get no picture
The dazzle works on Adobe flash media but I couldn't get it to work on vvmix. I have the ezcap vvmix sees it but I can't get a picture. Can you verify the settings I should use?
