I have problems when recording to disk.
Thanks: 46 times Was thanked: 2 time(s) in 2 post(s)
Hi all I have problems when recording to disk. the recording, do not open or lock freezes. I have tried several times and remains the same. I lost a few films. try 2 AVI files, approximately 130 MH. I mesclar are not recorded well. which could be the problem, I have everything updated .
Play the Video Recorded is the problem. locks, or freezes, and vmix2012v2 closes branded alone or mistake
--------------- google traductor ------------
Joined: 1/13/2010(UTC) Posts: 5,366  Location: Gold Coast, Australia Was thanked: 4788 time(s) in 1643 post(s)
Sorry the translation didn't work very well, could you try to explain the issue a little simpler? If you are having trouble playing back AVI files, chances are you will need to try a different codec.
I only recommend, DeckLink MJPEG, CineForm or MPEG-2. All other formats may cause issues as they are untested and many codecs are poorly designed.
Martin vMix
