ELCHAPIN
#1 Posted : Sunday, March 4, 2012 12:25:35 AM(UTC)
ELCHAPIN
Hi all
I have problems when recording to disk.
the recording, do not open or lock freezes.
I have tried several times and remains the same.
I lost a few films.
try 2 AVI files,
approximately 130 MH.
I mesclar are not recorded well.
which could be the problem, I have everything updated .
Play the Video Recorded is the problem.
locks, or freezes, and vmix2012v2
closes branded alone or mistake
--------------- google traductor ------------
#2 Posted : Sunday, March 4, 2012 4:38:35 AM(UTC)
Sorry the translation didn't work very well, could you try to explain the issue a little simpler?
If you are having trouble playing back AVI files, chances are you will need to try a different codec.
I only recommend, DeckLink MJPEG, CineForm or MPEG-2. All other formats may cause issues as they are untested and many codecs are poorly designed.
