Can't get C920 resolution right
Joined: 10/30/2014(UTC) Posts: 16 Location: Asheville, NC
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi All,
I've been trying to get the resolution right on a Logitech C920 webcam correct. Most combinations come back saying the capture resolution is not supported by this device. A number of them work but in all cases, the format stretches the frame wider. I folded a piece of white paper to a square and hold it up for each. On the best of them is always about 5 parts long by 4 parts tall.
I'm using the Logitech software. vMix Basic HD, Windows 7, i5 64-bit with a graphics card.
Any ideas on how to make this work? Your comments are appreciated, Thanks, sh
@ luthierwnc
What are all your the settings, from vMix global settings to camera options?
Joined: 1/7/2015(UTC) Posts: 7  Location: Uk Thanks: 2 times
luthierwnc
I use 4 Logitech cameras on my set up, the settings I'm using are: logitech software 1080p NTSC-60HZ
vMixHd Camera inputs 1920 x 1080 NTSC 30p
hope this helps
Steve
Thanks Gents.
The issue seemed to be that vMix kept defaulting to the anamorphic setting.
Banger: I tried your setting and changed from anamorphic to widescreen. That got the dimensions right. In the recording setup, I tried 1820x1080 to match the input but got a lot of lag when I waved my arm in front of the cam. I scaled that back to 1280X720 and the lag improved dramatically.
Think I've got it for now. Thanks again, sh
Have you updated the camera drivers? Once I updated the drivers all the lag went!
